Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 03-25-2018, 11:30 PM   #1
1970 25' Caravanner
Incline Village , Nevada
Bathroom fan wiring help needed
We moved this bathroom fan to a different location and somwhere along the way I think these wires got disconnected. I think they were soldered on to the 2 contact points in the photo. Can anyone confirm this and does it matter on which contact point the blue and red wires go? This fan operated with a push button...first push was on high, second push was on low and third push was off. My hand is covering the single black wire that was leading to the push button.
Thanks.
Jeremy9107 is offline   Reply With Quote
Old 09-22-2018, 01:08 AM   #2
1970 25' Caravanner
Bathroom exhaust fan wiring help needed
Hoping someone will see this and offer help as still have not figured it out. This is the original bathroom exhaust fan in 1970 Caravanner. The switch has 3 wires on it (one is hidden in picture) red, blue and black. There is a tube structure on the back side of the triangular mounting plate on the other side of the solder joints with a black wire coming off one end.
Question is where does power and ground hook up? How does switch attach? and what wires attach to those solder joints?
Old 10-09-2018, 08:31 AM   #3
1970 25' Caravanner
figured it out
had not choice but to figure the wiring out on my own. hooked up battery and just began attaching wires until it started working. then tried combinations to get the high and low settings to operate. trial and error.... then success
was thinking power had to come through switch then off to fan, but in the end the power went directly to fan.
wiring was :
hot from battery to black leading into fan.
neutral from battery to fan switch black
blue on fan switch to solder point on fan plate
red on fan switch to solder point on fan plate (same point where black from fan attaches)
Name:	48 bathroom 1c exhaust fan wiring.jpg
Name:	48 bathroom 1d exhaust fan wiring solder gun.jpg
Name:	48 bathroom 1e exhaust fan wiring.jpg
Name:	48 bathroom 1f exhaust fan wiring wired.jpg
Help with '64 Overlander fan & light wiring, please! wigwag Electrical - Systems, Generators, Batteries & Solar 4 08-25-2014 05:48 AM
HELP HELP HELP - Wiring Diagram For '73 20ft Argosy therealtoddster Lights - Interior & Exterior 8 10-04-2010 02:03 PM
HELP!! Wood-handled Bathroom Ceiling Fan Cat Roof Vents, Skylights & Fans 0 08-19-2006 10:26 PM
Fan-Tastic fan??? definition needed hex Our Community 26 10-10-2002 02:17 PM
Wiring help needed zamboni Airstream Motorhome Forums 6 09-26-2002 03:50 PM
