Old 01-04-2015, 11:24 AM   #1
1969 23' Safari
fairfield , Pennsylvania
Bathroom fan 1969 safari
Where would I start looking for a bathroom fan?
russellsue is offline   Reply With Quote
Old 01-05-2015, 06:15 AM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
A photo would be helpful. My 86 has a 4" round fan in the shower stall with a push up, pull down exterior cover over it. My 66 has the standard 14" roof vent in the sleeping area, but nothing in the bathroom. There are just all kinds of ventilation fans available for RVs. I don't know what Airstream put in the 69s.
David
Old 01-05-2015, 06:34 AM   #3
1969 23' Safari
bathroom fan unit
Its sits just inside the bathroom door ceiling it has a round type blade looks like the cover had some kind of round switch in it its about 4 inches
Old 01-05-2015, 12:25 PM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Is the fan gone or the motor not working?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-06-2015, 05:31 AM   #5
1969 23' Safari
bathroom fan unit
The round fan cylinder is there but the motor is rusted, Blades turn
Old 01-06-2015, 07:10 AM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Well, it sounds like your 69 has a bath fan similar to my 86. Mine has a handle that is pushed up to open the vent. Then it has a rotary switch that turns on the fan motor. The fan blades are plastic. The fan blade is just pressed on to the motor shaft. The motor shaft has a flat on it that drives the fan blades.
The fan motor will not run unless the vent lid is pushed all the way up. The fan blades it the vent lid. If the fan motor was turned on, but can not rotate, it will trip a circuit breaker or fuse.
A rusty motor does not surprise. Does the motor run? Does the fan blade turn when the motor runs? Can you describe the problem so troubleshoot the problem you are experiencing?
I think 12v fan motors, rotary switches and fan blades are readily available at RV dealers or on line RV parts sellers. These parts are not Airstream exclusive.
David
Old 01-07-2015, 05:53 AM   #7
1969 23' Safari
bathroom fan unit
It does not have a handle it is a round vent that looks like it had a turn switch on it the blades moves, its a round drum type. when it rains it leaks I have closed it up and if I cant find a replacement I'll seal it up the motor does not run but the blades turns I would like to get an exact replacement
Old 01-07-2015, 11:12 AM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
tried INLANDRV for the motor?
AIR #005
retired!
Old 03-21-2015, 11:51 AM   #9
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Hi we just rejuvenate yours, you can have the motor rebuilt an an electric repair place. I had mine glass beaded, repainted and the motor brushes replaced. Then we replaced the twist switch with the stubby three way switch available at Vintage trailer supply. I'll try to find pics for you
thesignlady is offline   Reply With Quote
Old 03-22-2015, 11:39 AM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
we replaced ours with a Fantastic Vent. It works great and was easy to install.
AIR #005
retired!
Old 04-01-2015, 01:12 PM   #11
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Time to replace the unit with a modern bathroom vent fan. You can get it from Vintage Trailer Supply Part # VTS-152 $69.95 or your local RV store.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
6000RBTA Fan-tastic fan in 2004 Safari exallen Windows, Doors, Locks & Vents 0 07-01-2013 03:07 PM
2004 Safari leaking around bathroom vent fan DJW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 01-03-2011 05:12 PM
1978 safari bathroom fan snkrichards Roof Vents, Skylights & Fans 2 11-28-2010 01:18 PM
Fan Tastic Fan in 07 FB Safari gaylejoe Roof Vents, Skylights & Fans 1 09-04-2010 01:53 AM
Bathroom Exhaust Fan for 71 Safari rrpranch Roof Vents, Skylights & Fans 12 06-26-2007 07:57 AM
