Old 09-01-2017, 02:45 PM   #41
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Originally Posted by rmkrum View Post
When I went to college on the subject, it took about a year just to understand the math...and it still makes my head hurt to this day. And yes, before you ask, we did all that with a slide rule, that I still have, Justin case the calculator batteries die...
Since you brought up batteries, which way do the electrons flow, + to - or - to +?
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 09-01-2017, 04:39 PM   #42
2007 22' International CCD
Out the - side, in the + side. Has been that way forever...
Then you look at diodes and transistors, and the blasted arrows still show conventional current flow, i.e. + to - . It's electronics-- it down not always make sense.
Vacuum tubes, of course flow from - (cathode) to + (plate).
Now you are making my head hurt again
rmkrum is online now   Reply With Quote
Old 09-04-2017, 07:44 PM   #43
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
So Here's some more 'hurt'.
BRITISH CARS. Do they still wire them with a + positive ground??
Or did realty smite them?
MelGoddard is offline   Reply With Quote
Old 09-04-2017, 07:54 PM   #44
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
The wife's 2006 Jaguar has a negative ground system. 1980 MGB has negative ground, 1978 Triumph spitfire same deal. My dad's 1959 Triumph tr3 was a positive ground but converted to standard negative ground when we restored it.
1973Argosy is offline   Reply With Quote
Old 09-04-2017, 08:06 PM   #45
Hi
The schematic is correct. It shows a proper transformer delivering two hot lines 180 degrees out of phase.
It took a while of studying, but I think that I 'got it'.
Old 09-05-2017, 12:29 PM   #46
Obviously-NOT
Kalispell , Montana
(Understand, question from old nuke sub plumber, who took one class for Electrical Theory for Mechanical Operators, in 1977)
So, in AC circuits, the switch is on the "hot" black leg to isolate the juice from the load when switched off. In DC circuits the switch/fuse is in the red + wire; so the load will light up with a short between load and red wire switch?
No, I guess the short would be back to the same frame the negative pole is bonded to?
Old 09-05-2017, 07:51 PM   #47
My 1961 Austin, A-55 Mk.2 "Cambridge" had a positive ground.
I don't remember what my 1965 MGB. was. I didn't keep it long enough to find out.
Old 09-06-2017, 09:40 AM   #48
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you ever get into a vehicle that is set up with a 6V electrical system, there is a pretty good chance it also has the positive hooked to chassis / grounded. Nothing is ever certain, but it's a good bet.
Old 09-06-2017, 08:46 PM   #49
Hi
And then there was a Toyota Land Cruiser with a 6 cyl. diesel.
It had a 24 Volt system.
I really wanted one, but that 24 V. system was a deal breaker.
NOBODY sells 24v auto accessories; unless one wanted to use aircraft equipment in it.
Old 09-07-2017, 09:41 AM   #50
Half a Rivet Short
Hi
If you ever head that way, there is a whole world of military vehicle "stuff" set up for 24V. Not going to find it at the local tire store, but it's out there.
Old 09-08-2017, 02:08 PM   #51
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Hi
ModelT was neg grand, model A was pos grand, Allchevys neg grand....ford tractors pos grnd
Old 09-10-2017, 07:34 PM   #52
Yer makin' MY head hurt now.��
Old 09-10-2017, 08:19 PM   #53
Yup. Just proves that standards aren't...as any experienced engineer can tell you. Let's don't talk about the so-called RS-232 communications standard, for example.
Old 09-11-2017, 10:44 AM   #54
Half a Rivet Short
Hi
No different than that red traffic light. Around here it seems it's "just a suggestion ...".
Old 09-11-2017, 01:20 PM   #55
Basic RV Electrical Question, I think
Yes, especially in certain neighborhoods in SoCal area....sometimes I think they are a challenge for certain Macho types to get through them lest they get delayed for a minute or two!
Old 09-18-2017, 01:10 AM   #56
2016 27' Flying Cloud
Riverbank , California
Does anyone have experience attempting to use a 30amp electric dryer receptacle for a 30amp RV service/supply?
Thank you in advance for your help.
AS Blessing is offline   Reply With Quote
Old 09-18-2017, 04:52 AM   #57
Obviously-NOT
Kalispell , Montana
Yes, did one when I first got my trailer. I actually wired a generator outlet box from HD to the outside wall from the dryer, via a box inside with an a/c style quick disconnect, then made a jumper with a 30 amp rv outlet and 30 amp generator plug. 30 - 50 pigtail, EMS, 50 amp TT shore cable. The jumper could be used also with a 30 amp generator, if it didn't have a 30 amp rv outlet.
Old 09-18-2017, 04:58 AM   #58
Obviously-NOT
Kalispell , Montana
The website at the bottom of this page is a good source for all the outlet and plug numbers. You just need to tap one of the 120v 30 amp hot leads, the neutral, and ground from the 240 dryer service. I added the disconnect inside so the male generator box contacts weren't hot when I wasn't plugged in.
Old 09-19-2017, 08:01 AM   #59
Half a Rivet Short
Hi
It's normally a 240V outlet. You will need some sort of adapter to hook it up. As noted above you can do one that will work pretty well with a 50A trailer or a very different one for a 30A trailer.
Old 09-19-2017, 08:11 AM   #60
Obviously-NOT
Kalispell , Montana
Tapped the new 30 amp feed into dryer outlet box, inside wall to back of new A/C pull style disconnect box mounted on interior wall. Flexible conduit out of that box punched through exterior wall to back of 30 amp generator connection box (male tines exposed for 30 amp generator cord). It was what HD had available at the time and allows future generator hook up to back feed service panel through the double breaker 30 amp dryer circuit.
Very basic electrical... splyb Lights - Interior & Exterior 7 02-29-2016 09:29 PM
Basic Electrical Question (1992 25' Excella) Doug C Batteries, Univolts, Converters & Inverters 3 11-13-2012 08:17 PM
1967 Safari - Basic electrical - photos attached denverdingo Electrical - Systems, Generators, Batteries & Solar 12 10-19-2011 12:33 AM
"I think I can, I think I can, I think I can".... 2Rhinos Repairing/Replacing Floor &/or Frame 14 08-17-2011 02:39 PM
Basic Electrical Solar Panel Questions BillWill Generators & Solar Power 11 12-16-2008 08:10 AM
