Old 12-14-2004, 10:48 AM   #1
walter1's Avatar
1964 22' Safari
Foresthill , California
Bargman 99 & LEDs?
Has anyone yet found or reproduced a true replacement for the tiered Bargman 99 “wedding cake” taillight used on 60’s Airstreams that is actually tiered, looks correct, perhaps down to the Bargman 99 lettering, and that also incorporates bright LED light array such as used on newer school buses? These would look correct on restored AS by day and be much safer at night.
I’ve searched forums and seen Inland RV and AS Dreams reproduction Bargman 99s and replacement LED array lights but not both tiered and LED array.
walter1 is offline   Reply With Quote
Old 12-14-2004, 04:08 PM   #2
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
lights
I've seen the ones from Airstream Dreams.com and they look really nice. If you're committed to LED I'd try to adapt an LED brakelight to the Bargman duplicate. There's so many LED lights now on the internet and dealers that you should be able to find one that fits close enough to make it work.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 12-14-2004, 06:50 PM   #3
Wardinbb's Avatar
1964 24' Tradewind
Big Bear Lake , California
Tall Call
Walter, I'd have to agree w/ Tin Hut, you will probably have to make them yourself via the HeathKit approach. I replaced the Bargman wedding cake lenses with the schoolbus LEDs. Vitually the same diameter but no step to them, slightly radiused edges however. It seems there was some design theme consciousness when A/S did the 60's units in that the hub caps and stop light lenses tied into one another with the steped designs. Too bad they didn't carry it through to the cabinet hardware and handles. But the split rims are pretty much gone and it seems the Bargman's are next in line as history items. It's been mentioned that the lid off a quart paint can will suffice for the backing plate for the Bargman's. So you can get what you want by drillin' out the paint lid, soldering & wiring in the LEDs and poppin' reproduced lenses from A/S Dreams on. The LEDs come as a sealed unit so I don't think you'd be able to just change out the cover on them. I think we all would like to see a PIC if you did em up proud.
Ed
Wardinbb is offline   Reply With Quote
Old 12-15-2004, 02:56 PM   #4
walter1's Avatar
1964 22' Safari
Thanks, perhaps I'll try the AS Dreams repro lenses and think about building LED interior unit.
Ed, where did you acquire the schoolbus type LED lights?
Hmmm...How many LEDs are in the array inside the schoolbus type?
Do they all light at once or are some taillight, others brake light?
If I just run this wire there, solder these and then splice into that...ZAP! POOF!!
Old 12-15-2004, 04:11 PM   #5
LOST , Hawaii
Smoke 'em if you got 'em
Most leds run on 3 volts or less so you will need a way to drop the voltage.
John
74Argosy24MH is offline   Reply With Quote
Old 12-15-2004, 05:55 PM   #6
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Question
Does the socket for the bulb sit upright, or at a 90 degree angle, facing directly out toward the lens?
Old 12-15-2004, 08:12 PM   #7
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Talking Led,s
A good electronic store sells led with a resistor build in so you can run on 12 volts. I build a night light for our AS . Used 2 green led's . This operates from 12 volts. I beleive they make them in many colors. In the store i went to they had red, green , blue and white but no clear. I want to replace the incadesen bulbs in the tail lites with led's use less power and are much brighter.
Russell
RUSSELL is offline   Reply With Quote
Old 12-15-2004, 08:35 PM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
John
how about 4 wired in series?
that should work on 12 volts.
john
you call them ferrets, i call them weasels.
Old 12-15-2004, 08:57 PM   #9
Old Paint, rolling again.
sfixx's Avatar
1973 Argosy 20
Lorain County , Ohio
Images: 12
school bus tail lights
I'm in the process of changing to school bus lamps on my '73 Argosy. I really like the look though a purist may feel otherwise. I was looking for brighter and safer within my budget which doesn't allow for LED's. My parts source and pictures are shown here at my new web log:
http://stephenfixx.blogspot.com/
sfixx is offline   Reply With Quote
Old 12-16-2004, 09:48 AM   #10
LOST , Hawaii
john
That works also. Parallel series groups of 4 leds.
John
Old 12-16-2004, 10:38 AM   #11
Wardinbb's Avatar
1964 24' Tradewind
LED source
Walter, here's where I got mine, http://www.led-r-us.com/sttlights.shtml, this link should take you directly to product page. They are 7" diameter with 60 LEDs, do the stop, turn and tail functions and are $40. each.
Here's a PIC of mine installed, with help from the Forum, together with a license plate lamp from AirStream Dreams. Have fun.
Ed
Old 12-16-2004, 04:10 PM   #12
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
those look great ward!
john
Old 12-17-2004, 08:50 AM   #13
walter1's Avatar
1964 22' Safari
Ed, those look great. How much trouble was it to mount them? New holes to cut/drill? Looks as if these new ones are 4 screw where old Bargmans are 3 screws. Any chance of putting those lights together with new reproduction Bargman lenses? That would give the look and function I'm after, but yes cost a bit.
Old 12-17-2004, 12:01 PM   #14
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Originally Posted by sfixx
nice web site, enjoyed cruising thru it.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Theodore Bargman Box Craig 1978- 1979 Excella 500 26 03-16-2014 04:02 PM
Vintage Bargman Electrical Connector flyfshr Electrical - Systems, Generators, Batteries & Solar 5 12-17-2011 06:12 AM
Needed Bargman Door lock yoderconsult Doors & Locks 6 03-24-2010 10:56 PM
Bargman #99 wedding cake Tail light needed CindyH Lights - Interior & Exterior 8 10-16-2002 08:52 AM
