Old 07-23-2015, 09:24 PM   #1
1971 21' Globetrotter
1965 17' Caravel
1951 15' Cruisette
Bare Copper Wire To Frame
I know this is a stupid question, but I cannot remember where the bare copper wire that is attached to the frame goes. Is it the converter or the junction box? Thanks in advance!!!
KATYBELLE is offline   Reply With Quote
Old 07-23-2015, 09:32 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Either or both.. If there is a ground bus that grounds too.
Old 07-23-2015, 11:27 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
One lead to each of the above, plus the ground bus, with separate screw-type connections at the frame for each ground lead. I would use a minimum 6AWG for this purpose, although I NEVER use solid wire in any of my installations.....and that includes Romex. It's all marine grade cable and class K welding cable.
Remember that a ground cable should be...at minimum the size of the largest current carrying cable in the device, as it provides the return path for the DC circuits, and a mechanical safety for the AC circuits.
Copper Wire? Evets Lights - Interior & Exterior 7 10-19-2011 02:53 PM
Painted vs Bare Aluminum Exterior Tinsel Loaf Ribs, Skins & Rivets 86 11-25-2007 12:05 PM
Installing bare alum ceiling LI Pets Upholstery, Blinds, Walls & Interior Finishes 3 03-05-2007 09:55 AM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
Window sills (painted or bare aluminum)? Andy R Windows & Screens 2 06-04-2002 01:01 PM
