Old 10-27-2014, 09:31 PM   #1
2012 19' International
Baraldi Fuse
I just bought a 2012 International that needs a new fuse for the Baraldi vent. The previous owner did not have the fuse for me to find another just like it.
After searching for hours and hours online trying to find specifics, can someone tell me which specific fuse to buy (brand, size, store, internet store)? All the information that you can provide would be helpful.
Thanks!
HankHill is offline   Reply With Quote
Old 10-27-2014, 10:13 PM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
I checked my Beraldi. It says it is 6amp max fuse. Have you checked your DC distribution panel for the missing fuse / circuit...which would indicate what type of fuse you need. A 12v 6amp fuse should be available at an auto parts store.
arktos55343 is offline   Reply With Quote
Old 10-27-2014, 10:20 PM   #3
The fuse that needs replacing is the one above the vent that is screwed in. Forum posts indicate that this is now supposed to be a 5 amp fuse but was originally a 3.5 amp fuse.
Old 10-28-2014, 01:17 AM   #4
2012 25' Flying Cloud
Milan , Michigan
Baraldi Fuse
Hank,
I have a 2012 FC. While camping, a couple of month's ago, I ran into a fella with a unit just like mine. While talking, he told me about having blown the fuse you're talking about and how it took him quite some time to find the fuse he needed. I asked for the specs and he provided the following.
3.15A 250V Glass Slow Blow Fuse (TTL-A-027-5EA)
These can be purchased on E-Bay:
5X 3 15A 250V Glass Fuses Slow Blow Time Delay GDC 3 15A T3 15A 3 15 Amp | eBay
I hope this helps,
Chip
BlueChip is offline   Reply With Quote
Old 10-28-2014, 06:21 AM   #5
Retired.
. , At Large
You can get the OEM fuse from your friendly Airstream dealer. You can also get LED replacements for the halogen bulbs in the range hood, which will lower current draw and reduce the chance of blowing another fuse.
Old 10-28-2014, 07:31 AM   #6
M. Smith's Avatar
2020 27' International
Tuttle , Oklahoma
Blew the fuse in my Baraldi also. After much searching, found a replacement 3.5 amp at Radio Shack. Then, of course, I read on the forums about replacing with a 5 amp.
M. Smith is offline   Reply With Quote
Old 10-28-2014, 07:35 AM   #7
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Airstream technical staff approves the 5 amp mini fuse and Radio Shack typically has them in stock.
2013 25 FC FB (Twin)
2013 Suburban 2500
https://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 10-29-2014, 03:40 PM   #8
Directly from Airstream service:
Hello, The fuse in the Baraldi range hood is a 5 x 20, 5 amp 250 v slow blow fuse. Here is a link to Radio Shack.
5.0A 250V 5x20mm Slow-Blow Glass Fuse (4-Pack) - Radioshack
Old 02-19-2017, 02:19 PM   #9
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Originally Posted by m. Smith View Post
blew the fuse in my baraldi also. After much searching, found a replacement 3.5 amp at radio shack. Then, of course, i read on the forums about replacing with a 5 amp.
ok but where is the fuse?
Old 02-19-2017, 03:08 PM   #10
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Baraldi Fuse
If I remember correctly it's either under the metal filter for the vent or just behind it on the right rear side when you're facing it in front of the oven. It's one of those old classic kinds you unscrew. I changed it once in 2013 and can't remember for sure...not near the trailer or I'd take a pic for you.
Old 02-19-2017, 03:47 PM   #11
Winemaker
rgwatkin's Avatar
2022 25' Flying Cloud
Avila Beach , California
When I received my new 2012 FC the first problem I had was the stove vent blowing fuses. The AS dealership replaced the motor and it did the same thing, finally the AS dealership called AS/Baraldi and came to the conclusion that the fuse needed to be a 5amp mini fuse. After that no issues.
rgwatkin is offline   Reply With Quote
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 01:41 PM
LED Conversion: Baraldi Range Hood Lights TinTin Stoves, Ovens & Microwaves 5 07-13-2014 02:38 PM
Baraldi Stove Fan Repair spudnik Stoves, Ovens & Microwaves 0 07-29-2013 09:47 AM
Baraldi fan basket spudnik Stoves, Ovens & Microwaves 0 07-27-2013 07:27 PM
Baraldi Range Hoods dznf0g Stoves, Ovens & Microwaves 1 04-25-2013 05:13 PM
