Old 06-27-2011, 05:02 PM   #1
1999 19' Bambi
Phillips , Wisconsin
Bambi Battery
Greetings. Our 1999 Bambi has one battery. Is there any reason I couldn't put another battery in parallel with the existing one? Thanks! Ric
ricnjane is offline   Reply With Quote
Old 06-27-2011, 05:22 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Lots of people add a 2nd 12V battery in parallel, or go to a pair of 6V batteries in series. There are philosophical disagreements on which is best, because in theory the 6V batteries themselves have some advantages, but if one of them has a problem you're sunk, whereas you could temporarily take the bad 12V out of the circuit and run with reduced capacity.
The challenge is where to put the 2nd battery on a small trailer.
David
05 Bambi battery size Davadar Batteries, Univolts, Converters & Inverters 1 06-27-2011 04:32 PM
Battery Bank Upgrade Gwuk Batteries, Univolts, Converters & Inverters 5 03-24-2011 08:18 AM
Only one battery charging heslinhotel Batteries, Univolts, Converters & Inverters 11 02-21-2011 08:49 PM
