Old 01-27-2010, 04:53 PM   #43
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I will throw this out.
If you have had rainy, damp weather the outside outlet can get moisture in it and cause the GFCI to trip and difficult resetting until dried out.
Other than that follow Jammers post he has covered the troubleshooting side very well.
Garry
Old 01-27-2010, 04:57 PM   #44
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Originally Posted by Jammer View Post
Not necessarily if there is a persistent ground fault in the branch circuit wiring.
Agreed.
But on more the one occasion I have had GFCI breakers which wouldn't reset and proved to be defective. If you replace the breaker and it still won't reset, your problem is elsewhere, AND you now have a spare breaker .
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 01-27-2010, 06:22 PM   #45
Spacepod Ps's Avatar
2003 22' International CCD
Beaverton , Oregon
I honestly can't say how much I appreciate everything you all have offered today. It's been heaps of help!
So, here's where I'm at right now.
I replaced the main power cord, so that side of the troubleshooting is taken care of, and from what I can tell it's going strong(so far so good).
I fiddled with the breaker in the pics; i.e. took it out of the panel to take the pics, tried working with the test button and flipping it from the on to off position several times. Put it back in the panel. Fiddled with it some more; ie flipping it from off to on and pressing the test button,the test button finally worked as it should and tripped the breaker. When I tried to reset the breaker it still took a couple of tries before it stuck in the on position. But, right now everything is working as it should. All of the outlets are back and the breaker is in the "on" position. So, I'm going to leave it for tonight and keep an eye on it for a while and see if anything else happens.
If everyone else is in agreement, I'm going to let this dog lay for a bit and chalk the experience up to a bad power cord. Although, I don't want to just stick my head in the sand and remain ignorant to a possible much larger problem. So, if you think further investigation is necessary I'll follow your lead and trust in experience over my ignorance any day.
Spacepod Ps is offline   Reply With Quote
Old 01-27-2010, 06:37 PM   #46
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by guy99 View Post
Agreed.
And it's better to have and not need than need and not have. Spares ARE a good idea.
Glad things worked out....good luck.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 01-27-2010, 06:45 PM   #47
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
right on space pod
Okay, you have experienced a double, possibly triple whammy. GFCI's when first introduced failed miserably. But, in the past 20 years they have been very reliable. What I suspect happened is: 1) bad cord or poor connection 2) #1 caused GFCI to begin tripping, and you may have reset it. 3) once it tripped, heater, and whatever, cooled off or began a new 'On" cycle, which allowed the GFCI to pass current again 4) scenario repeated, until the tripping mechanism inside the GFCI began to fail 5) "monkeying" with said GFCI finally got it to where you are now.
Okay, permanent cure: 1) replace cord and treat it like you want to keep it a long while. 2) replace the GFCI circuit breaker that is in the AC distribution box. 3) You MAY have to replace the GFCI receptacle (outlet) if not now, perhaps in the future-once a GFCI operates it begins a death spiral...the mechanism can only survive so many operations. 4) fix the orig cord and keep it relatively handy. An extra circuit breaker to match those in your AC service box ain't a bad plan, either.
All the advice about unplugging, being sure female receptacles, etc are dry, watching the polarity of shore power source, learning to use safely a VOM (volt ohm meter) is all wonderful and accurate-you can take it to the bank. IMHO, don't use the 15 (or20) amp adapter unless it is the only solution. be sure to twist tightly the marinco plug when first hooking up. just practice safety and gentleness when using the AC cords, adapters, etc.
Look forward to meeting you when you get back to Oregon/Washington/somewhere closer than Florida.
ol Bill-retired old power guy....
wmarsha is offline   Reply With Quote
Old 01-28-2010, 08:18 PM   #48
richinny's Avatar
2011 34' Classic
If you look in this photo, the two screws that hold the wires in place are visible on the left side, facing the camera.
thanks for solving my mystery! is there a specially tipped driver for that or is a flat bladed screwdriver ok? it seems to have a slot and a square hole in the center of the screw. i don't want to see the replacement get mangled.
Ricky
Old 01-28-2010, 09:08 PM   #49
Wise Elder
Jammer's Avatar
2010 30' Classic
A flat bladed screwdriver works fine as long as it's the right size. You can use a square drive, instead, if you have one, but I never do.
Old 01-29-2010, 05:44 AM   #50
richinny's Avatar
2011 34' Classic
thanks jammer!
Ricky
Fried hot water heater diode jimlegs 2006 Safari SE 12 09-09-2012 10:36 AM
Electrical - this cord goes into a green box rollin home Electrical - Systems, Generators, Batteries & Solar 5 08-13-2009 11:29 AM
Help--fried converter JustinL3 Electrical - Systems, Generators, Batteries & Solar 8 08-14-2006 01:54 PM
Power hitch jack - fried? Toasty's Dad Hitches, Couplers & Balls 9 02-06-2006 10:26 AM
Need help!-Finding thread about electrical cord. WayWard Wind Our Community 5 03-25-2003 07:37 PM
