Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 12-02-2006, 10:51 AM   #1
rickandsandi
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Back-up Wiring
Hello everyone- need some help!
We have an '05 22' Safari and I just got a very cool back-up camera system. I know this will not solve all backing up problems, but it sure will help backing into some of those small SP sites. One more set of eyes if you will. The problem is that you need to connect the camera to the back-up light power lines. You can not leave the camera on all the time. Since our Safari does not have back-up lights I am hoping that the wiring harness does the line for it. I had pulled one of the tail lights out this morning and there is a cluster of wires back there. I checked the wiring diagram but it was no help. The only wire I could not account for was a brown wire. Has anyone any idea if there is a line for a back-up light in this cluster?
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
rickandsandi is offline   Reply With Quote
Old 12-07-2006, 07:17 AM   #2
JKWoodrow
Profile:  Springfield , Ohio
Back up circuit
The brown wire is for your tail lights. If you have a seven pole trailer connector, you can use the center pole for back up lights. Most camera setups need only to tie into the reverse signal from the monitor which makes it easier. You can tie into it at the reverse switch located on the steering column.
JKWoodrow is offline   Reply With Quote
Old 12-07-2006, 07:39 AM   #3
rickandsandi
1960 24' Tradewind
JK-
Thank you for the post, you are the first response! The camera actually only needs a power lead, the signal is wireless. What I am hoping to find is the actual wire in the tail-light harness which is connected to the center post from my TV. What I am trying to avoid is running a new wire from my electrical connections to the rear of my AS.
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
Old 12-07-2006, 08:16 AM   #4
Mike Lewis
Profile:  2006 30' Classic
Farmington , New Mexico
Images: 14
rick---our 05 and 06 Classic's came with back up lamps standard . I assumed all Airstreams had them, apparently not. That said, I can't believe they would make up two different wiring harness' for the different models but more likly one harness and just not use the extra wire. Perhaps a call to the factory Tech. Assistance would help. Another thought is that you could open the trailer end of the 7 pin connector and see if all 7 are being used.--pieman
Mike Lewis is offline   Reply With Quote
Old 12-13-2006, 12:04 PM   #5
rickandsandi
1960 24' Tradewind
Greetings Pieman-
I have an email off to JC, but have not yet heard. At least it's good to hear someone else agrees with me that the harness must be universal.
I guess you could rip out one of your tail light assemblies out and let me know which color the reverse light wire is!
happy Holidays!
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
Old 12-13-2006, 01:19 PM   #6
2airishuman
2airishuman's Avatar
Profile:
it will be interesting to read the reply from j/c...
as background....
in 2004 or so a/s got a proposal from a small company to provide a back up camera on trailers near the license plate.
so a/s started including a 12v power wire in the harness, and as part of production...
turns out the company was so small they also wanted a/s to fund the camera production...
so no cameras were to be had and the deal fell apart...
but a/s continued to include the extra wire FOR a 12v camera in the wiring near the plate.... for 05/06
i wonder if they are still doing this?
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 12-13-2006, 02:19 PM   #7
rickandsandi
1960 24' Tradewind
2air-
I have two inquiries into JC so as soon as I hear anything I will post it. Thre has to be a wire back there!
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
Old 12-13-2006, 03:28 PM   #8
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
How about jumping off your licience plate or tail light?
Just make sure your lights are on and you have power
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 12-13-2006, 04:35 PM   #9
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Originally Posted by rickandsandi
2air-
We have had that system under test for 190 continuous hours.
Voltage at the camera was 13.5 volts DC.
The camera and monitor are working as well after the test, as they did at the beginning.
The word from some is that "you can't do that," meaning you cannot leave the system on continuously.
The test results show that not to be true.
Accordingly, "you can" hook that system directly to the tail light or license plate light circuit. Simply turn your headlights on and your in business, not only to back up, but to also see what may be behind your trailer or motorhome.
For that matter, for those that do not have back up "radar" you can also install it on your tow vehicle or family car.
We have sold out our first shipment and are waiting for more to arrive.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 12-13-2006, 06:12 PM   #10
rickandsandi
1960 24' Tradewind
Well Andy-
Looks like I will be wiring the camera to the plate light! Still haven't heard from anyone about whether there is a revise light lead in the cluster or not.
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
To Columbia,CA and back... Safari Tim On The Road... 9 04-18-2004 03:04 PM
Wiring Diagram Needed 74Tradewind Electrical - Systems, Generators, Batteries & Solar 3 07-29-2002 12:21 PM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 11:03 AM
Holding Tank Wiring 74Tradewind Waste Systems, Tanks & Totes 1 05-23-2002 04:22 PM
Electric Brake Wiring JW84345 Brakes & Brake Controllers 3 03-26-2002 09:40 PM
