Old 10-25-2011, 03:05 PM   #1
ST77TW's Avatar
1977 25' Tradewind
Conway , South Carolina
Back up lights stay on constantly
I have a 1977 Tradewind and my back up lights are constantly on when hooked up to my truck with 7-way connector. Does anyone know why this happens or experience the same problem? Thanks for you help.
ST77TW is offline   Reply With Quote
Old 10-25-2011, 03:10 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Modern 7-pin connectors aren't mapped the same way that Airstream set the pinout on the umbilical. You'll just need to swap some wires around on the trailer side of the connection. The standard pin-out pattern is available all over the place (e-trailer, etc.)
David
DKB_SATX is online now   Reply With Quote
Old 10-25-2011, 04:43 PM   #3
ST77TW's Avatar
1977 25' Tradewind
I revamped the seven way until the running lights were the lights to remain on. No back up lights working, but when I brake they work and the brake lights work. I can live with this unless there are better options.
Thanks so much! Steve
Old 10-25-2011, 05:25 PM   #4
funkill's Avatar
reno , NV
Images: 27
Ahhh. That's what happened to mine when I had someone update my umbilical. I ended up removing the bulbs from the back-up lights because I figured it would scare the crap out of someone behind me when at a stop light. "Oh no, that woman driver is going to back-up over us!"
Laura
funkill is offline   Reply With Quote
Old 10-25-2011, 06:06 PM   #5
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
I had that problem when I bought a 78 years ago! Power feed was to back up lights, brakes were hooked up to back up lights. discovered when we tried to back the trailer. Change trailer end to conform with new standard!
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 10-25-2011, 07:24 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
Now I imagine you have the charge wire crossed with the running lights. Do the running lights only come on with the tow vehicle ignition switch turned on? Or are they on all the time the 7-way is plugged in? Does your breakaway switch work? Power jack have power?
It's easy to get everything right and it's a one time effort. For me it's worth a little time to get everything right . . . especially with towing lights. My .02
back up lights
Electrical issues with clearance lights 1987_345 Classic Motorhomes 13 08-25-2011 08:13 AM
LED interior lights: A complaint hampstead38 Lights - Interior & Exterior 0 03-23-2011 08:38 AM
Minus these lights SilverHoot Lights - Interior & Exterior 20 02-13-2011 09:04 AM
Moving from center lights to multiple puck lights mikeandnora Lights - Interior & Exterior 10 02-11-2011 09:47 AM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 10:14 PM
