A backup camera is a real bonus. When you want to change lanes, backing up and just checking out what is behind you, like should you pull over and let them go by.
I have nothing but pros, just love it, you will love one too.
Been kinda curious about this, myself. What kind of setup did you go with, and how did you set it up? Any photos?
Cheers, Dave
"Finish." AIR #4188 1994 34' Limited / 2002 Chevy 3500 CC 4x4 D/A Equal-i-zer Hitch / Jordan Ultima 2020
Very nice.
Can we get a little more info? Is it a kit, or did you build it from parts? Is it wireless, or is there a cable from the trailer to the tow vehicle?
There are two cameras and monitor, they are hard wired. There is a four pin interface plug next to the trailer plug. They also have a built in microphone (the little hole in the camera) but I didn't hook up that feature. The other camera is in the rear window of the van that keeps a look on the hitch and when not in tow is the van's backup system. Great feature and has made lane changes safer.
how many duckets?
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
Has anyone had experience with a wireless backup camera and their trailer? Don't want to have extra wiring between trailer and truck.
Talked with http://www.nvsystems.com/rvsystems.htm, but he is unable to directly accept credit cards. Had bad luck with PayPal before, and don't want to use them again.
Has anyone used this company? Any other providers?
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic dinette
2003 GMC Sierra 2500HD CrewCab/Shortbed diesel
Hensley/Prodigy
One inexpensive way to have a rear view camera is to purchase a one camera security camera system (Wallmart about $85) with a wireless link. The wireless link solves the problem with connecting to the tow vehicle (but the picture does "roll" from time to time.) I use 12 volt cigarette lighter plug to power the camera instead of the 110volt to 12 volt converter. You can buy these plugs at Radio Shack and wire it yourself using the wire off the converter.
The camera will give a a "false" rear view mirror image and must be reversed ...right to left....(because your rear view mirror is really a reversed image.) This can be done by aiming the camera into a mirror that looks out the back of your unit through the back window. On my unit the camera points down to a horizontal truck mirror that looks out the back and successfully reverses the image.
I mount the video montor on the floor hump of the tow vehicle aimed at the driver. Simple approach but it works!
Mark
1984 31' Excella, mid bath, king size bed
1998 Chevrolet Suburban K2500, 7.4L/454 c.i., 4WD, Pullrite Hitch
AIR No. 2375
OK - I can't resist! I have my notebook computer mounted on the console in order to use the DeLorme navigation system --- lots of fun, and truly valuable from time to time. Could you somehow mount a computer monitor camera using "Bluetooth" or one of the other fancy computer gadgets - like the built-in wireless capability - that I know absolutely nothing about??? That way, I could simply switch screens when I wanted to take a look out back. Aside from "wireless," could you use the camera hard-wired to the USB port?
