Old 09-28-2005, 06:14 PM   #1
till's Avatar
Lisle , Illinois
Images: 108
Back from the dead sort of
Will a Univolt II (1967 ish) bring back a deep cycle that was reading about 3 volts?? It seems to be, but then again, batteries are not my thing.....
Most of the 12 volt system seems to work now that there is a battery in the circuit.
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 09-28-2005, 06:18 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Tedd, there are special chargers to bring back badly discharged or sulfated batteries, if the Univolt won't get the job done, maybe a trip to your local auto and truck battery distributor with the battery for them to see what they can do will be in order.
Old 09-29-2005, 06:41 AM   #3
till's Avatar
Lisle , Illinois
Images: 108
Well the old Univolt was up to the challange. After about three hours of charging the battery was at 12.5 Volts. Left it off over night and checked the battery this morning, 12.5 volts!!! Yea!!! (Bringing this wrecked Overlander back from the dead for some short camping trips is fun) Turned the power back on this morning to let it finish off the charging.
Tedd Ill
AIR#3788 TAC IL-10
Old 09-29-2005, 09:25 AM   #4
norbert's Avatar
1993 30' Excella
whitewater , north of cheddar curtain
Images: 24
after a charge check your specific gravity...this will also tell you if you might have a dead cell...
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 09-29-2005, 09:46 AM   #5
till's Avatar
Lisle , Illinois
Images: 108
I will get a gravity tester (Isn't that a bathroom scale??? ) and keep an eye on the battery condition.
Thanks Terry and Norby.
Hey Norbrt, will you be out to the gathering in Pecatonica??
Tedd Ill
AIR#3788 TAC IL-10
Old 09-29-2005, 10:01 AM   #6
norbert's Avatar
1993 30' Excella
Images: 24
sorry, im leavin for seattle next week.
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
Back from Yellowstone casarodante On The Road... 14 09-21-2005 10:39 AM
Homemade backup camera 83Excella Airstream Trailer Forums 28 08-17-2005 12:31 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
