Old 12-29-2017, 10:58 PM   #1
swilly43's Avatar
escondido , California
Atkinson Solar controller
My solar controller display PVDM4-LC almost always indicate 0% battery life. Doesn't matter if in full sun or not. Main charger indicate house batteries in float status and voltage is >12.7V. No change when shore power is removed and the solar should be charging at less than 12V. The display flashes indicating low battery voltage even when battery is above 12.5V. Is something wrong with the solar panel, charger or display?
2016 Interstate grand Tour
swilly43 is offline   Reply With Quote
Old 01-06-2018, 04:56 PM   #2
swilly43's Avatar
I contacted Lewster offline and he thought this means a faulty solar controller. After a bit more digging and troubleshooting, I was able to get the display working by applying light pressure to the potentiometer on the back of the circuit board of the controller display and seems to operate as described in the literature. . See picture. Sometimes the display will revert to abnormal behavior but then starts working after applying the same pressure. Wiggling the cable does not affect it. There must be a defective solder joint somewhere. Will look into a replacement. The red cirlcle was shifted in the photo to the connector. The pot is just obove the connector in this photo.
Old 01-07-2018, 05:49 PM   #3
2015 30' Classic
Pleasanton , California
The RJ connector and the crimp inside the connector would definitely raise suspicions in my book as the likely culprit. I would try reattaching a new connector to the cable if possible.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Atkinson Sun Explorer charge controllers Mhawke2 Sprinter and B-van Forum 39 11-20-2018 09:24 AM
Upgrading the solar charge controller from Atkinson to MPPT FlyFishinRVr Sprinter and B-van Forum 98 05-18-2018 10:46 AM
Location of the Atkinson Charge Contolller Display kit on a 2017 Interstate Mitou Electrical - Systems, Generators, Batteries & Solar 1 03-09-2017 07:41 AM
Univolt replacement now or later, and does solar affect which charge controller? mlepisto Batteries, Univolts, Converters & Inverters 3 11-05-2009 07:16 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
