Old 08-21-2011, 11:25 AM   #1
Glang227's Avatar
1976 Argosy 26
Lucan , Ontario
Images: 14
Argosy Wiring problem
My trailer works just fine when it plugged in but when unplugged, nothing works at all, and never has (as long as I've had it). I have replaced the univolt with intellipower convertor and nothing's changed. Any suggestions as to where to look first or what might be missing
1976 Argosy 26
Glang227 is offline   Reply With Quote
Old 08-21-2011, 11:31 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I would make sure that the negative of the battery is connected to the shell of the trailer and you have continuity. With a volt meter connect the - to the shell and the + to the positive terminal on the battery. You should see 12+ volts.
Richard
Old 08-21-2011, 11:49 AM   #3
Glang227's Avatar
1976 Argosy 26
Lucan , Ontario
Images: 14
Here's a couple of better pics
ID:	138286   Click image for larger version
Old 08-21-2011, 12:18 PM   #4
Glang227's Avatar
1976 Argosy 26
Lucan , Ontario
Images: 14
Just checked, and I have 13V at every point when the trailer is unplugged, so I don't understand why the trailer 12V doesn't work when unplugged from 120V. I admit 12V wiring is not my strong point.
Old 08-21-2011, 12:44 PM   #5
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Where are you checking the 13VDC ?
Across the fuse panel or across the battery ?
Where are you putting the meter negative lead, the positive lead?
Garry
Old 08-21-2011, 01:20 PM   #6
Glang227's Avatar
1976 Argosy 26
Lucan , Ontario
Images: 14
Across the battery, to the trailer, across the fuse block, basically everywhere, I just checked the battery after being unplugged for a while and now I get nothing, I guess even new batteries can be bad, gonna change it out and go from there, good thing for warranties.
Greg
1976 Argosy 26'
2006 Dodge Mega Cab 1500
Old 08-21-2011, 03:16 PM   #7
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Look in the lift up trunk area for the ground conection. Take it apart and clean all connections. I fixed another argosy with the same problem, just a bad ground connection.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 08-21-2011, 04:57 PM   #8
Whitefawn
whitefawn's Avatar
1978 Argosy 24
Scottsville , Virginia
Another thing to check: inline fuse, etc
If you find that the ground is good and working I discovered another fuse in the bottom of the bathroom closet between the battery compartment and the fuse panel. It is an inline fuse near the floor and was covered up with wiring, etc. I found it accidentally. Your battery wire doesn't look like it has an inline fuse, but I can't tell for sure.
In our 1978 Argosy I also discovered that in the bottom of my (original) fuse panel, there is a 50amp fuse between the univolt terminal and the battery terminal. We had loss of power intermittently and discovered that the rivet holding the 50amp fuse clamp was loose and we were losing power to the rest of the fuses in the fuse box. The quick fix would be to check all rivets in the fuse clips and and use a punch to re-tighten the rivets. My solution was to cut the distribution fuses off of the fuse panel and attach a new fuse panel with individual fuses to the old panel. I connected the new fuses to the main wire coming from the converter. We are going to post a thread soon with pictures on that project.
Looking at the pictures, your panel looks different from ours- possibly updated, but may still have loose rivets that could cause problems.
Joe
aka Whitefawn
whitefawn is offline   Reply With Quote
1993 30' (late 92 model) Excella :: 1993 Airstream Excella1000 arcamedies Airstream Registry Discussions 2 07-28-2012 09:10 AM
Argosy maiden voyage. shortcake All Argosy Trailers 18 09-29-2011 10:33 AM
Argosy :: 1974 Argosy dlb56hdt Airstream Registry Discussions 0 08-19-2011 08:32 AM
1991 Excella 1000 - New Radio need wiring help! jbbaldwin Audio, Video & TV 0 07-13-2011 12:04 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
