Old 07-13-2019, 12:48 PM   #1
UncleBad's Avatar
2018 27' Tommy Bahama
Oro Valley , Arizona
Anyone know what type of electrical connection this is?
We stayed at the Route 66 RV Resort and Casino last night as we passed through Albuquerque. Very nice park BTW and the location for the Meet in the Middle Ralley (which we are unable to attend) but I digress.
Anyone know what type electrical connection this is? It was on the electrical pedistal opposite of the normal 30 and 50 amp connections.
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Old 07-13-2019, 01:26 PM   #2
Mollysdad's Avatar
We used to see those before all the TV trucks went to cam lock.
I think it's a 100 amp three phase?
Possibly for entertainer's tour busses that have 5 ac units.
Old 07-13-2019, 01:47 PM   #3
Long Island , New York
The label on the bottom is attached and copied here. Not sure which image is more readable on your computer/device/phone, but each one will appear larger if you click on it. An electrician would be better at explaining things.
N.B. the caution about an "acceptable grounding program."
Good luck,
Peter
Name:	AF power pedestal 13 July 2019.png
Old 07-13-2019, 01:52 PM   #4
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
It is a “pin and sleeve” receptacle. I have only seen them in an industrial setup like a kitchen or factory. Becoming more popular the last several years. However I have never seen one at a RV park. It surprises me that they have one as you obviously need a matching plug.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 07-13-2019, 01:59 PM   #5
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
It’s a 4 pin 100 amp receptacle
Hubbell is the brand.
Old 07-13-2019, 02:23 PM   #6
2018 28' International
Fayetteville , Georgia
It says “Eaton”.
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 07-13-2019, 02:51 PM   #7
UncleBad's Avatar
Yeah - I did a cursory search of the Eaton site and didn’t intially find anything and am traveling so can’t research. There were quite a few large buses there.. and forgot to ask when we were leaving.
Old 07-13-2019, 08:06 PM   #8
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Originally Posted by brick1 View Post
It says “Eaton”.
The Pedestal is made by Eaton. The plug is Hubbell.
https://www.stayonline.com/wiring-device/iec-60309-4-wire-receptacles-7167.asp
Old 07-13-2019, 08:41 PM   #9
The Tin Man
2017 27' International
SoCal , California
It almost looks like my Tesla receptacle...
2017 Serenity 27FB
Registry Name
"Rivets for the Tin Man"
WBCC #4913
sandollars is offline   Reply With Quote
Old 07-14-2019, 05:59 AM   #10
1973 25' Tradewind
1962 22' Safari
Augusta , Georgia
we use similar receptacles for 480/3 phase 100 Amp (welding receptacles). Ones I'm familiar with has catch/keeper to secure plug in receptacle. Similar to what GMFL identified, just different voltage. Industrial applications have all kinds of weird plugs/connectors.
No clue why it's in RV park???
DGJackson is offline   Reply With Quote
Old 07-14-2019, 06:04 AM   #11
This sounds logical IMO.
Old 07-14-2019, 07:03 AM   #12
Mollysdad's Avatar
Yes.
Most tour busses run their generators 24/7 because they have no easy access to power. 20kw.
The plug goes in one way due to one pin smaller, and the male part has a ring that turns a quarter turn to lock.
We got away from those because a 100' power cable was impossible for one guy to lift.
The other possibility is they have shows recorded and the TV truck or uplink sits there.
Old 07-14-2019, 07:38 AM   #13
UncleBad's Avatar
Anyone going to “Meet in the Middle”?
We won’t be able to make it, but those going could ask.
https://arizona.airstreamclub.net/ra...-middle-rally/
Old 07-14-2019, 10:03 AM   #14
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Based on the ratings on the plug, it could have some pretty crazy voltages on it. I would not go near one without some real information on how it is wired. Since you need a nutty adapter anyway and they are mighty rare ... that's an easy decision.
Old 07-14-2019, 10:07 AM   #15
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Attachment 346331
How about just calling the park and ask them what it's used for.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-14-2019, 03:28 PM   #16
Classy Roscoe
It’s the power for a portable uplink for sat communication. They are the power source for television, data uplink vans and other such use. Medical MRI units also use the type of connection. Really good for frying RV’s
You will also see them used by carnivals but once connected are divided down to 220 vac for heavy motors and further for 110 vac.
Some beverage companies use a similar plug for 3-phase coolers on the trucks. TV vans use the 3-phase as well.
Jekerrville is offline   Reply With Quote
Old 07-14-2019, 06:41 PM   #17
UncleBad's Avatar
And miss out chatting it up with all you guys and gals? ;-0
I actually did. It’s a 100 amp connection for some class A busses that require it with multiple coolers, etc.
Old 07-14-2019, 07:22 PM   #18
Iron tepee #35
1993 34' Excella
andalusia , Illinois
That is 1 grounded, 1 grounding (neutral), 2 hots (110 to neutral on each, or 220 between the two hots) just like in your house. I would be hesitant to use it without a meter to check it with first...if done wrong, it would get ugly in a hurry.
mikeoxlong is offline   Reply With Quote
Old 07-15-2019, 02:44 AM   #19
Same thought FWIW!
Old 07-21-2019, 09:29 AM   #20
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
That's for all the spaceships and UFO's out in that area. Lock your doors at night!
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
farafield is offline   Reply With Quote
hello, I was wondering if anyone here is from Las Vegas and know of anyone that rents kikiboi Our Community 6 01-05-2014 03:52 PM
Anyone know what type hitch this is? aaumpine Hitches, Couplers & Balls 4 10-29-2009 05:48 AM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
