Old 02-01-2010, 02:07 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Any Xantrex Link 1000 experts here?
I installed this battery monitor in my Sovereign over the weekend and love it. But I do have a few questions on how to use a few features and how to interpret some of the data.
1958 Overlander
2011 Wolf Creek 850N TC
4CU 1st VP
mello mike is offline   Reply With Quote
Old 02-01-2010, 03:01 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Expert, no. But always willing to weigh in on discussions involving Coulombs.
Old 02-02-2010, 09:24 AM   #3
Wabbiteer's Avatar
Jupiter , Florida
I have several similar devices - what are your questions?
Wabbiteer is offline   Reply With Quote
Old 02-02-2010, 03:34 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
The Ah and T displays the first couple days didn't make much sense but after fully charging my two golf cart batteries they make sense now. Here are a few questions I still have:
1. The manual states that when fully charged, the four charge lights will illuminate green with the furthest right light flashing green. This right green light has yet to flash even after charging for a full day.
2. The Time display reads 255 right now. Does this time correlate at all with the total amp hours (220ah) of my batteries? I initially thought so but this doesn't appear to be the case.
3. It appears that it took a couple days (including fully charging my batteries) for the Link 1000 to "learn" my batteries. Is this normal?
4. How often do you need to resynchronize the Link 1000 with your batteries?
5. When recharging, will the Ah display read 220 (my batteries have a 220amp hour capacity) if my batteries were to be completely discharged (I'd never do that, just asking).
1958 Overlander
4CU 1st VP
Old 02-02-2010, 06:15 PM   #5
Wabbiteer's Avatar
Jupiter , Florida
I've got two Trace TM-48s charge monitors w/o the remote functions. Reading on the Link-1000's it shows they've done some interesting things.
Finishing charge above 90% takes multiples of the time it took to reach 90% - that last 10% comes at a steep energy price but that is where the chemistry of the lead plates is healed. On a flooded lead-acid battery actually obtaining 100% charge is kind of theoretical since the minute after removing current its fallen back, 98% plus is good enough for Government work..
About the winky green LED (Q #1) there is a clarification in the FAQ's :
Manual: If your system’s charging current does not fall below 2% of battery capacity at the end of the charging cycle (that is, when the battery should be full), you will need to change the Charged Current Percentage setting. (A fully charged battery is indicated when the green LED flashes on the BATTERY STATUS light bar.)
FAQ: The flashing green light is not an indicator of a full battery. It is an indication that the computer has recalculated charge efficiency. A cycle of greater than 10% of the battery capacity is required for recalculation of the charge efficiency factor and the flashing green lights. The other conditions required for recalculation of charge efficiency and the flashing of the LEDs include: 1. Charged voltage above the set point, 2. Charged current below the set point, 3. Kilowatt hours removed and returned, 4. Above conditions met for three to five minutes if alternative energy protocol not selected.
Question #2 - the 255 display might* be "The time remaining in your battery before it is completely discharged" ... 255 is the largest number of hours the unit can display...
Question #5 - If* you've got the Links' logic dialed in with the advanced settings done correctly you very well could see 220AH 'used' on the display just before the battery imploded into a mini black hole singularity and vanished from our time-space continuum... Just kidding about the implosion but yes its possible,
The rest of your questions I'd have to have a unit ticking along somewhere nearby to answer...
I like the battery box you fabricated pictured in your photo gallery - you got a control panel or inverter & woring area you could picture other than the remote link-1000?
New Xantrex ls99 All Argosy Trailers 0 05-16-2009 04:17 PM
Xantrex XADC-60 doorgunner Batteries, Univolts, Converters & Inverters 5 11-25-2008 04:55 PM
PC Experts--I need help Minnie's Mate Off Topic Forum 15 11-17-2008 01:33 PM
Do we have any experts on plastics here? cameront120 Cabinets, Counter Tops & Furnishings 3 09-23-2008 11:05 AM
Xantrex Link-10 Choice battery monitor mswartz Batteries, Univolts, Converters & Inverters 2 03-13-2004 05:26 PM
