Old 08-01-2015, 12:27 PM   #1
2015 25' FB International
Santa Barbara , California
Any recommendation for solar panels
As my 12V system seems to die rather quickly, I am considering the purchase of solar. So far, I've got a quote of $975 for Windy Nation brand solar panels installed; or $1,500 for Go Power solar panels installed.
M and M is offline   Reply With Quote
Old 08-01-2015, 07:54 PM   #2
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
have you checked out AM Solar
These High Efficiency Solar Panels turn Sunlight into Power for your RV Lifestyle
they have good product and Lewster is active on the boards is you have questions.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 08-01-2015, 08:25 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Check out the systems by Renogy.
http://www.renogy-store.com
MICHAEL
Old 08-01-2015, 08:30 PM   #4
2016 30' Classic
Erie , Colorado
What are your goals? Just top of the batteries? Serious off grid time? Size of battery storage you have? And ask any installer for references on their solar installs on Airstreams. If they haven't got experience on AS trailers find another installer.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 08-02-2015, 11:35 AM   #5
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Highly recommend the AM Solar folks for the system components. We have used A&P Vintage Trailer Works in Paradise, Texas as an installer for our complex systems and custom work done at the same time.
The Classic has eight 100 watt rated solar panels and a 600 amp-hour lithium iron phosphate battery. It has a Tri-Star 60 MPPT solar controller and a Magnum MS-2812 inverted/charger. The 23D will have at least four and perhaps five 100 watt solar panels, depending on roof space, and a 300 amp-hour lithium iron phosphate battery. It will have the Blue Sky SB3024iL solar controller and a Magnum MSH3012 converter/inverter.
The goal was to have enough panels and battery that off grid camping can be done without generators for longer periods of time. The weak spot in the Airstreams when off grid camping is usually black/grey tank capacity.
Old 08-02-2015, 11:35 AM   #6
tampa , Florida
First read about solar, then read some more.
Solar is quite simple, yet many people end up with an incorrect system. First determine yourself what you need. There are lots of resources available for that, both on this forum as elsewhere.
Van Williams
cargovan is offline   Reply With Quote
Old 08-02-2015, 11:40 AM   #7
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
AM Solar
Another vote for AM Solar. They were extremely helpful and I ordered everything I needed in a kit. I've had the system over 8 years and not a single problem. All installation directions are included so I just took my time putting it all together.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-02-2015, 01:44 PM   #8
carl2591's Avatar
2005 31' Classic
Van is right on reading and read more info.. for some good reading, and a guy some hate and others praise, check out Handy Bob Solar..
https://handybobsolar.wordpress.com/
If you work with AM Solar guys they will steer you right. Its more the proper equipment and wire size vs lots of solar panels. With the right system 2-3 100 watts panels will keep most 6 or 12 volt batteries in good shape 90% of the time.. you might look at changing out 12v batteries for 2-6 volt golf cart batteries like the trojans t-105 or such. more capacity and heaver cells for long life.
Van Williams
Carl, Raleigh NC
Old 08-02-2015, 03:56 PM   #9
SilverEagle6's Avatar
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up , Traveling the USA
Zamp Solar...portable solar panels.
Jeanne and John, and always with us...Jake
2008 30' Classic Ltd Rear twin, 2014 Ford Super Duty
WBCCI 3100, unit 12, TAC USA-1, Escapees 129379
https://instagram.com/silvereagle3100/
SilverEagle6 is offline   Reply With Quote
Old 08-02-2015, 05:12 PM   #10
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Not to dis AM Solar, but I'm as tight as they come, so I went with (2) 100 monocrystalline Renogy panels and an eBay charge control that may actually be MPPT. I put a lot of money into larger wire and upgraded connections, along with roof-mounted breakers (in an ugly weatherproof metal Hoffman box). I figure I've got about $800 in it, not counting the gas for umpteen trips to HomeyD.
If you're not 100% comfortable with wiring, Lew and AM solar is a very, very good bet.
Old 08-02-2015, 05:56 PM   #11
2014 30' Flying Cloud
Ponce Inlet , Florida
The system you should buy is dependent on your solar needs and the proper size of your battery bank. Just topping off batteries after one night or serious boondocking complete w 1000w + inverter and large Battery Bank.
Proper installation, wiring size and equipment location make a big difference in efficiency.
Lastly the efficiency of the panels, controller, inverter ...... will also make a difference in your system performance. More efficient components may cost more but will produce more power in a smaller footprint if space is important.
I have an AM Solar System w/ AGM batteries installed by Lew very efficient but not cheap.
Lots of great info. in this forum and the net in general. Ask installer about wiring size equipment, placement ... and check out references. If you don't like the answers find a different installer.
Good luck
Benn
Beach Bum is offline   Reply With Quote
Old 08-03-2015, 05:48 AM   #12
Look for us at Assateague
1975 31' Sovereign
1955 22' Safari
Ringoes , New Jersey
Save money.
I installed solar panels and a charge controller for under 300 dollars. Find panels that provide 15-19 volts dc which will charge 12v batteries just fine. I swapped out my wet-cell marine deep-cycle batteries for 12 volt AGM wheelchair batteries which last longer than engine-cranking batteries.
thompooley is offline   Reply With Quote
Old 08-03-2015, 11:25 AM   #13
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
AM Solar is worth the cost. You are getting the best possible products with peak performance. I researched for awhile some of the other options, including Renology. I was going to pull the trigger, but the specs are not on par.
"Good enough" is not the way I like to do things.
That being said, AM Solar get's their panels from Grape Solar, they are some of the best in the industry. The other panels that are excellent that you can usually buy used from eBay are KYOCERA 120 Watt panels.
You could piece together one of AM Solar's bigger kits for about $300 less, but I couldn't figure out how much would be spent on the small misc. things, but it adds up.
When I got AM Solar's kit, I understood why.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Solar panel recommendation easler7267 Boondocking 7 06-05-2015 10:10 PM
Adding panels on top of panels instead of replacing? The-Marco Ribs, Skins & Rivets 18 08-02-2014 04:53 PM
NorCal Solar installation Recommendation? burnsdl Generators & Solar Power 3 05-20-2013 11:48 PM
Any recommendation on a new furnance? Aktundra 1961 - 1963 Bambi 6 10-29-2011 10:30 AM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 07:47 AM
