Old 10-03-2019, 03:57 PM   #1
1968 28' Ambassador
Southwest Ranches , Florida
Any harm in increasing wire gauge down the line?
Hello,
I have a 7-way umbilical cable that has 14 gauge wires for all of the wires that aren't ground or brakes. The 14-gauge wires will go mainly to different types of lights.
I previously purchases a ton of 12 gauge marine wire and no 14 gauge for some reason. Instead of buying 14 gauge, is there any harm in using 12 gauge connected to the 14 gauge from the umbilical cable?
Thanks!
Nick
mashburn.nick is offline   Reply With Quote
Old 10-03-2019, 04:09 PM   #2
2007 22' International CCD
None whatsoever. The fuses in the tow vehicle will still protect the smaller wires.
Wire size needs to be a minimum for the design current. It does not hurt if it is bigger than minimum needed.
Old 10-03-2019, 05:50 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Ummm ..... errrrr ...... The more common wire gauge for umbilicals is 10AWG. A lot of vehicle fusing is rated accordingly. A 30A fuse in your truck will not do a very good job of protecting 14 AWG (which needs a 15A fuse ....)
Old 10-03-2019, 06:03 PM   #4
Hm. Only a few of the wires, like electrical brake power and ground in my umbilical are ‘bigger’ than the others. The rest are a bit lighter.
Old 10-03-2019, 06:51 PM   #5
1968 28' Ambassador
Ah, sorry. I should have clarified a bit more. Here's the cable coming from the TV to the junction box. https://www.towuniverse.com/Bargman-...icon-54006-010
My question is whether I can connect the Blue-Brown-Green-Yellow-14 gauge to a 12 gauge wire at the junction box.
Old 10-03-2019, 06:58 PM   #6
waninae39's Avatar
2017 22' Sport
NCR , Ontario
when our 7 way cable got damaged.
i replaced with one that used 12 and 10 gauge wire
waninae39 is offline   Reply With Quote
Old 10-03-2019, 08:13 PM   #7
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
There may* be the hazard of bulbs burning out in 1200 hours vs. 1500 hours since the 14.7VDC raw output of the alternator in FLA charge mode will not meet as much resistance volting along them fat conductors while crossing that 30~ feet of wire run
Well, at least the lamps my glow noticeably brighter.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Best wire connector for 12 gauge stranded wire jcarnevale Lights - Interior & Exterior 6 04-14-2014 08:18 PM
Welding on frame harm electric systems? Scotman Repairing/Replacing Floor &/or Frame 4 04-09-2014 04:27 AM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
WD-40....will it harm the finish? Chuck Exterior Restoration Forum 1 07-05-2002 09:50 AM
