Old 07-08-2012, 07:09 PM   #1
Medford , Southern Oregon
Any downside to getting a 2nd air conditioner?
DH and I are getting close to placing a order for a 27FB. He mentioned wanting the second air conditioner in the bedroom and I thought I read that there might be a downside to having the second unit.
We'll be contacting the dealership next week but I was wondering if someone might clear it up for me? As I understand it, the airstream will come with 30 amp service but if we add the second air conditioner, the airstream will then be outfitted with 50 amp service?
Other than the cost of adding the second unit, is there any other downside to ordering the trailer with a 2nd air conditioner?
sakthorp is offline   Reply With Quote
Old 07-08-2012, 07:13 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Other than another spot for potential leaks I don't see any downside.
MICHAEL
Old 07-08-2012, 07:15 PM   #3
Well, they simply replace the fantastic fan with a air conditioner, so there is already the potential for a leak
Old 07-08-2012, 07:37 PM   #4
Central , Mississippi
We love our 2nd AC. Being a 34' absoutely NO air was making it down the hallway to the bedroom. We installed it ourselves so I made a few non-standard choices...we have dual 30A inlets. The regular one operates the entire trailer, just like every other 30A 'Stream...the 2nd 30A inlet operates the bedroom air. If we get into a pinch an only have one 30A outlet we can choose to run just the bed room air. If we have 50A, I uses a 50A to dual 30A pigtail.
AND since the rear air only pulls 17A...I can plug it into a 20A circuit...(and the rest of the trailer in the 30A...)
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-08-2012, 09:05 PM   #5
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
It will always be too cold inside.
Duals on the MH, the rear one has its own power cord to be plugged into a regular 15/20 amp socket at campgrounds.
The 30 amp powers the front and everything else.
While on the road, the gen powers both.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 07-08-2012, 09:29 PM   #6
2013 30' International
etobicoke , Ontario
for what it's worth...
i really can't take the heat. (fair-haired, english blood and all that...). thus, i definitely thought we'd need the extra aircon unit for our bedroom. (we just bought a 30').
after being persuaded by the guys at the dealer, indeed it turns out they're right; the main aircon unit is quite powerful and sufficient (albeit it runs on the noisy side). it has lots of separate openings and multi-directional fins, that allow you to shoot the air straight to wherever you want it - back to the bedroom, straight downwards, forwards, or what have you.
depending on just how hot it is where you're at, it's a much much superior experience, just to have the awnings out (to deflect the sun), the windows open, and the fans on, compared with running the noisy aircon unit (or two).
aimcom is offline   Reply With Quote
Old 07-08-2012, 09:43 PM   #7
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
If you can't get any shade in your spot, are dealing with 100F or 35C and up, don't have the full awning package (or don't want to bother with it)... a 2nd A/C isn't a bad idea. It's not much more considering the total cost already... downsides are with 2 running, you'll be pushing the limits of a 30A service...
If it cools off at night or you don't need it super-cold during the day... 1 will do...
Friday is offline   Reply With Quote
Old 07-08-2012, 10:09 PM   #8
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
I was kidding about it being two cold...
get too !
Click To See Me Wet
1972 Argosy 24'...
Old 07-08-2012, 11:04 PM   #9
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
second airconditioner.
get the second unit! you will thank yourselves. You will need ear-plugs though.
Michelle TAC MT-0
Sarah, Snowball
Old 07-08-2012, 11:26 PM   #10
Ottawa , ON
If you run them both off your batteries, you'll find them batteries run flat pretty quick!
Old 07-09-2012, 04:10 AM   #11
fr8tshaker's Avatar
2006 34' Classic
Sioux Falls , South Dakota
50 Amps and 2nd AC
We chose to have the 50 amp service installed when we ordered our unit. It is one of the best decisions we made. We just use an adapter for the 50 amp cord when only 30 amp service is available.
Re: 2nd AC
When the temps get into the mid 90's or higher you will not regret the second ac.
Other advantages are:
-If one quits the other can be used until it is convenient for you to have the repairs made.
-When the temps do not require the use of both AC's we use the front AC at night and the rear AC during the day while we are up to reduce the noise level.
-When u have guest the temp for each area can be set for individual comfort.
Hope this is helpful.
FWIW
'shaker
2006 34' Classic LTD
2010 Ford F250 PSD
Hensley Arrow Hitch
fr8tshaker is offline   Reply With Quote
Old 07-09-2012, 11:27 AM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
I have dual air. The main disadvantage is that you then give up the fantastic fan in the bedroom. This means that less daylight reaches the bedroom, and it makes it more difficult to cool down the trailer when shore power isn't available.
Old 07-09-2012, 12:12 PM   #13
JFScheck's Avatar
Rockville , Maryland
Images: 33
Agreed - 30 needs two A/C units - 27, I would no only because my 25 was fine with one...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 07-09-2012, 12:55 PM   #14
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Ours only has one. We're going to the Outer Banks in August, so I'm curious to see how it will handle it there (that's the hottest/sunniest place we usually go, so if it can handle that we should be good for 99.9% of our trips). This will be our first trip to the Outer Banks with it.
My parents have an older 34' with only one, and they're looking at putting a 15K BTU A/C in theirs. It's not as good as a second A/C, but it's quite a bit easier and should at least help somewhat. We'll probably do the same when it comes time to replace ours.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
