Old 07-01-2016, 11:41 PM   #1
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Antique Signal-Stat Connector on trailer end of tow connection
So, I have a Signal-Stat set (male and female) on the trailer end of my towing connection to the vehicle.
They appear to be original on the coach, and the UV has almost disintegrated both. It doesn't look like either connector is still being manufactured.
So what does everybody do instead? Do you just hard-wire to the junction box inside the coach, or do you install another removable 7 pin connector of the type that's still available? Or does the 7-pin Grote connector match up? Or is there a Secret Stash of these somewhere that Mister Google doesn't know about?
Should I donate this set to the Smithsonian?
ID:	265708   Click image for larger version
Old 07-01-2016, 11:56 PM   #2
Seattle , USA
These are made by Pollak and are available in metal. GREAT quality. You can get them almost anywhere. They are inexpensive.
http://www.etrailer.com/Wiring/Pollak/PK11720.html
RareStream is offline   Reply With Quote
Old 07-02-2016, 05:17 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
FYI, that plastic-looking piece on the trailer is probably magnesium. Avoid overheating it when removing, such as having to cut off the mounting bolts. It will burn very nicely, and you can't put it out.
Old 07-02-2016, 10:36 AM   #4
Albuquerque , New Mexico
My AS had the same connectors with the same level of corrosion/wear. The newer style connectors inserted into the receptacle on the trailer, but the "hook" that keeps it from falling out didn't quite grab very well and I'm concerned about it working it's way out on the road. I'm going to replace the receptacle with the newer style that RareStream referenced. If you do keep using the old receptacle, you may have to swap a couple of wires. I had to look up the wiring for my 1969 because that older style wasn't wired exactly the same as the newer style. There are two wires you have to switch.
-Matt
Matt0k0 is offline   Reply With Quote
Old 07-02-2016, 11:38 AM   #5
1977 31' Sovereign
Lynnwood , Washington
The time has come to discard the old and upgrade with the new.
Any attempt to make do with what you've got (or find an "adapter") is something you'll later regret. The last thing you need is electrical problems on the road.
Tom
TomKirk is offline   Reply With Quote
Old 07-02-2016, 12:35 PM   #6
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Pig tails
These are used by virtually every tractor trailer on the North American continent .
Available in most every parts house and truck stops nationwide.
dannydimitt is offline   Reply With Quote
Old 07-02-2016, 02:40 PM   #7
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
I've got my old ones I took off, male and female. I didn't want to have to change the TV every time I traded. I even have two brake controllers since most tv come with them now.
Streamracer is offline   Reply With Quote
Old 07-05-2016, 06:42 PM   #8
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Easier to go with the RV plug....
Old 07-05-2016, 11:11 PM   #9
drboyd's Avatar
1978 25' Tradewind
You are absolutely correct, of course. But the zinc metal setup is sooooo cool!!
Signal-stat 3101 Keyholeren Electrical - Systems, Generators, Batteries & Solar 18 07-15-2009 06:39 AM
Signal Stat 9007 driftwood Electrical - Systems, Generators, Batteries & Solar 6 10-06-2003 06:57 PM
