Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-18-2005, 08:24 AM   #1
Profile:
antenna on 61 overlander
was wondering what the antenna on the curbside of my 61 overlander does and where the leads go to? It is about in the middle of the trailerand is about 8 feet long and has supports to keep it bent to the back of the camper.
heavyduty is offline   Reply With Quote
Old 04-18-2005, 01:20 PM   #2
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Airstream Registry
Greetings heavyduty!
Welcome to the Forums and the world of Vintage Overlander ownership!
The radio whip antenna was typically an indicator that the coach either had the International package or was originally equipped with the optional radio. The antenna was desigend to connect to a 12-volt automotive type radio (at least in my '64). The lead entered the coach through the sidewall in the far foward corner of the streetside wall inside of the cabinet in the front dome -- the point where the cable is found in your '61 may differ since I believe yours has a shelf rather than a locker (or cabinet) above the front window.
When my coach was restored/refurbished, the antenna was refitted with a CB lead so that I could have a permanently instaled CB (for communications at larger Rallys) in one of the roof lockers -- the original radio was missing when I purchased my coach.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Antennae On Overlander JAG Audio, Video & TV 17 03-03-2003 03:51 PM
Where do you suppose they put the antenna jack -73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
