Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 08-15-2002, 08:11 PM   #1
niftypkg
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Unhappy Antenna Mounting
Been here before. Got a rubber antenna mounting block about 2" OD AND three screws holding it to the skin. Turn the screws and apparently they are stripped on the other side?? Only solution I see is "cut the rubber" Anyone done that?? Suggestions??
niftypkg is offline   Reply With Quote
Old 08-16-2002, 09:31 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Machine screws were used to mount that antenna, that have nuts on the back side.
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 08-16-2002, 12:02 PM   #3
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
niftypkg,
I know we discussed this before on my '77 with the small ball mount and spring but no antenna. I saw a ball mount at an Advanced auto parts store here in Tullahoma. It looks like the same mount and everything. I am going to take measurements over the weekend and see if I am right. If so, all I will have to do is loosen the side screw holding 1/2 the ball mount to the other and replace the other side with the new 1/2 ball, spring and antenna shaft. Naw, it can't be that easy can it? I'll let you know.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-16-2002, 12:08 PM   #4
dienst1
dienst1's Avatar
Profile:
Images: 11
Antenna
Yes it is that easy. I had a damaged antenna mast on my 1981 Excella motorhome. I replaced the mast with one from a local auto parts store. The half ball mated with the one on the side of the motorhome exactly, even used the screw from the new one.
Dick
dienst1 is offline   Reply With Quote
Old 08-16-2002, 12:27 PM   #5
davidz71
davidz71's Avatar
Great, something easy for a change.
Craig
AIR #0078
3.73 rear end
Old 08-16-2002, 01:35 PM   #6
davidz71
davidz71's Avatar
niftypkg,
This is what my antenna mount looks like.
Craig
AIR #0078
3.73 rear end
Old 08-16-2002, 02:00 PM   #7
niftypkg
niftypkg's Avatar
Cornville , Arizona
Smile Antenna mount
Thanks for all the help. Andy says that the antenna is held in place with three manchine screws. Which means that the nuts are turning on the inside when I turn the screws and they won't turn out. I bought an antenna mount at RS, but it's for a CB-don't know the difference! The only one I could find with a side ball mount. Not keen on removing the panel on the inside to get at the nuts. Oh! Happy days.
Old 08-16-2002, 02:17 PM   #8
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Loose antenna
Hey guys,
I have the same antenna, and it is in one piece. (not broken However it is loose between the antenna base and the body of the coach.
So I get from your posts that I have to remove an interior panel to gain access to tighten the mount?
>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 08-16-2002, 04:52 PM   #9
Commercial Vendor
That antenna is still available from Airstream.
inlandrv.com
airstreamparts.com
Inlandrv.com
800-8777311
Old 08-16-2002, 05:13 PM   #10
Action
Moderator dude
Action's Avatar
Phoenix , Arizona
Images: 13
That's awesome.
How do I remove it?
>>>>>>>>>>>>>>>>Action
Old 08-16-2002, 05:13 PM   #11
davidz71
davidz71's Avatar
Success guys and it was simple, at least for my application since there were no nuts on the inside.
Craig
AIR #0078
3.73 rear end
Old 08-16-2002, 05:15 PM   #12
davidz71
davidz71's Avatar
I used the old base, new phillips screw, new ball/spring and mast.
Craig
AIR #0078
3.73 rear end
Old 08-16-2002, 05:38 PM   #13
Commercial Vendor
If the base still looks good, I would replace the mast only. That should take about 2 minutes, unless you want to partly remove an interior panel.
Then you should have a couple of beers handy, you know, just for moral support.
inlandrv.com
airstreamparts.com
Inlandrv.com
800-8777311
Old 08-16-2002, 05:43 PM   #14
davidz71
davidz71's Avatar
Andy,
That is why I crossed my fingers that I could find a match for my antenna. It sounds like niftypkg has a different antenna than mine. Action, does yours look like mine or does it have 3 screws like a mini CB ball mount?
Craig
AIR #0078
3.73 rear end
Antenna JLD Electrical - Systems, Generators, Batteries & Solar 13 08-31-2006 08:41 PM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
Satellite Antenna Don in E Texas Electrical - Systems, Generators, Batteries & Solar 2 04-25-2003 03:57 PM
Weather Radios jcanavera Off Topic Forum 15 04-08-2003 09:47 PM
Antenna Drive Gear CO_Don Audio, Video & TV 0 02-06-2003 04:45 PM
