Old 10-10-2002, 02:31 PM   #1
PatCrusse's Avatar
Red face Antenna connection
Call me ignorant, or just call me dumb.
I cannot figure out how to use the antenna on my '74 Tradewind. There are two locations inside the trailer that have a white plastic box. The boxes both contain a 12volt socket and two holes that say "antenna." How do I connect my TV to the "holes?"
Patrick
Patrick Crusse
'74 Tradewind 25', Rear Bath - Center Twin, Mostly Original except wood floors.
Tow Vehicle: '99 Dodge Ram 2500 w/ Cummins Diesel, Auto Trans. Tows great even without equilizer hitch.
PatCrusse is offline   Reply With Quote
Old 10-10-2002, 03:08 PM   #2
Chas's Avatar
Images: 22
Mine had that same setup which I replaced when I put a amplified weingard antennae setup on it. I think those holes take some sort of a male banana connector.
Chas is offline   Reply With Quote
Old 10-10-2002, 03:15 PM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yeah, its an old-style plug for the flat-wire cable. can't get them anymore...
What I did was disconnect the antenna wire from the back of this plug, and connected it to a 300ohm-75ohm converter. (radio shack) This has 2 screws on it to which you attach the antenna wires (doesn't matter which wire goes to which screw), and a coaxial type plug to which you can connect a modern coaxial cable to your tv.
Someone posted a link here once to a catalog outfit that had the entire 12v outlet/coaxial connector wall plate. If they don't make one that is set up to have antenna wire connected to the back of the plate, you can always use the converter I mentioned, and just hide it behind the wall.
Antenna JLD Electrical - Systems, Generators, Batteries & Solar 13 08-31-2006 08:41 PM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
TV antenna repairs lbf78SvgnInt31 Audio, Video & TV 7 07-28-2003 07:02 PM
Satellite Antenna Don in E Texas Electrical - Systems, Generators, Batteries & Solar 2 04-25-2003 03:57 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
