Old 04-15-2009, 11:23 AM   #1
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
Another electrical question
With everything in the trailer turned off. When we hook up the 12 volt battery. we get a small spark when we attach the cable. This tell me that I'm drawing electricity somewhere in the trailer, Correct?
Could it be the intellipower? Is this normal or not. I've disconnected the battery the last 2 nights. We hasn't been connected to shore power.
Annette
bullydogsmom is offline   Reply With Quote
Old 04-15-2009, 11:58 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
It could be one of two things.
If you are plugged into 120 at that time it is the converter attempting to charge the battery. This is OK.
If you are not plugged into 120 at that time it could be several things. Is the amplifier for the tv turned on? Do you have a CO2 monitor that is always hook up? A small arc is quite common. If you have a battery monitor in your control panel hook up the battery and watch the battery level on the panel after a week. If the level drops there may be a problem but right now I would not think it is necessary to disconnect the battery every night.
2004 Excursion 4x4
Old 04-15-2009, 11:58 AM   #3
Utahgoldrup's Avatar
1991 25' Excella
Salt Lake City , Utah
I have had this happen to me as well, I have the main power switch turned off inside and am not hooked to shore power, when I attach or unattach the terminals, I do get small sparking.
Utahgoldrup is offline   Reply With Quote
Old 04-15-2009, 11:58 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Annette
That explanation makes sense. Try pulling the fuses or turn off the breakers and putting them one at a time and repeat your spark test. When you get a spark that is the circuit there is a draw on. Depending on your trailer there are parasitic draws (equipment that draws electricity even turned off) such as the audio system and some of the appliances.
Old 04-15-2009, 12:16 PM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Does your refrigerator have a logic board?
Vaughan
Old 04-15-2009, 01:46 PM   #6
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I think the answer is simple (which may prove I am). When you attach the second lead to the battery, assuming the battery disconnect switch is not off, you are completing the circuit. The second before you touch the battery terminal, there may be enough voltage to arc between the cable and the terminal. This is normal.
Gene
Old 04-15-2009, 03:03 PM   #7
1972 25' Tradewind
Thanks for all your suggestions. We will try them all one at a time starting tomorrow and see if we can resolve the issue.
Annette
Old 04-15-2009, 03:06 PM   #8
2007 25' Classic
Hydes
Normal
craftsman is offline   Reply With Quote
Old 04-15-2009, 04:50 PM   #9
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
My dad always told me that when hooking up a battery or jumping a car, always attach the positive terminal first and then attach the ground. Then reverse it when disconnecting...ground first followed by the positive. This way sparking /arcing is reduced to a minimum.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 04-15-2009, 05:39 PM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
Gene
This is normal, and I don't think concerning, but doesn't it indicates there is a closed circuit somewhere with a draw?
electrical question Cochese Lights - Interior & Exterior 7 07-29-2007 10:59 PM
Electrical question Silvertwinky Plumbing - Systems & Fixtures 1 04-23-2007 08:59 PM
Electrical Question extiger Electrical - Systems, Generators, Batteries & Solar 5 04-09-2007 06:10 PM
electrical question dsmith Electrical - Systems, Generators, Batteries & Solar 27 03-05-2006 06:56 PM
Electrical Question Alex Electrical - Systems, Generators, Batteries & Solar 5 01-10-2004 10:12 PM
