Old 04-12-2015, 06:11 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Amp Requirement
I've recently seen campsites that are labeled with 20 amps, 30 amps, or 50 amps. How much power does an AS require, assuming A/C is needed?
I'm a complete novice to camping and I hope to get a AS in the not too distant future.
Old 04-12-2015, 06:19 PM   #2
richw46's Avatar
Lexington , Kentucky
30 amp plug if you have one AC unit, a 50 amp if there's two. You can't run the AC or heat pump on 20 amp but everything else should be OK. Campgrounds try to accommodate everyone, even campers who may not have any adapters but need to plug in for laptops, mattress inflators, etc.
You can get adapters (dog bones) to fit your house plug or convert a 50 amp to a 30 amp. Some of the 30 amp plugs are in bad shape at some locations so we use a 50 to 30 adapter and plug into the 50 amp.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 04-12-2015, 06:25 PM   #3
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
And usually (but not always) if the campground has 30amps there will also be a 20amp in the box; if it's 50amps they will also have 30amp and 20amp
Landrum is offline   Reply With Quote
Old 04-14-2015, 03:02 PM   #4
Hans627's Avatar
Thank you! How many amps will the electrical system in a AS be able to handle? For example, if a 50 amp campsite was the only one available would it be OK to use it even if you only need 30 amps?
Old 04-14-2015, 03:22 PM   #5
Landrum's Avatar
Sure. Your AS wouldn't actually be using 50amps. You'll just need one of the adapters (dog bones) that lets you plug your 30amp cord into the 50amp outlet. You can also get an adapter that lets you plug into a 20amp circuit, but in that case you would need to be careful with what you use (no air conditioning or heat pump).
Old 04-14-2015, 08:08 PM   #6
Hans627's Avatar
Got it and again thanks!
Natures Head power requirement steveirving Waste Systems, Tanks & Totes 12 11-14-2015 03:37 PM
Samsung tv goes on & off & on & etc jump Electronics & Connectivity 22 03-03-2015 06:01 PM
Multi Axle Tire Pressure Requirement dbj216 Tires 11 07-02-2014 05:27 PM
generator amp requirement for 25' safari jetjocky Electrical - Systems, Generators, Batteries & Solar 1 08-29-2011 05:51 PM
