Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 05-11-2008, 02:57 PM   #1
tphillips
Profile:  1967 20' Globetrotter
Houston , Texas
Aluminum Wiring
I have a 1967 globetrotter and from what I can tell, the 12 volt system is wired using aluminum wiring while the 110 volt is copper. Is this anything to be overly concerned about? I did notice that the PO connected a new water pump with copper connections to the aluminum wiring in the trailer just by twisting the two together, which I assume will need to be altered to eliminate whatever risk is present with aluminum and copper together, but otherwise does having the 12 volt on aluminum present any problems?
tphillips is offline   Reply With Quote
Old 05-11-2008, 03:30 PM   #2
Dan4odm
Commercial Vendor
Dan4odm's Avatar
Profile:  Currently Looking...
Colfax , North Carolina
I don't think so
With more than 10 years experience in the shop of the Out-of-Doors Mart
I have seen this before and have never seen it to be a problem.
Dan4odm is offline   Reply With Quote
Old 05-11-2008, 03:54 PM   #3
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
You're the second CA-built Airstream I know of
Originally Posted by tphillips
I have a 1967 globetrotter and from what I can tell, the 12 volt system is wired using aluminum wiring while the 110 volt is copper. ...
Your Globetrotter was built in California.
My Overlander was built in Ohio with the reverse of the above.
If your 12 volt systems work as expected then you have no problem. If not, then you must battle aluminum oxide (rust) on the connections. Considering a 12 volt system, there is no appreciable safety issue involved.
Ohio-built Airstreams need more attention.
Tom
Old 05-11-2008, 07:05 PM   #4
Leipper
Profile:
use some dielectric grease on the connections -Dielectric Silicone Grease - you can find it at most hardware and automotive stores.
Bryan
Leipper is offline   Reply With Quote
Microwave / Aluminum Wiring centennialman General Appliance Topics 2 03-01-2008 09:20 AM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
Aluminum wiring Tin Hut Electrical - Systems, Generators, Batteries & Solar 1 10-17-2003 10:26 AM
Aluminum wiring Tin Hut Electrical - Systems, Generators, Batteries & Solar 3 09-12-2003 05:47 PM
Wiring Happycampers Electrical - Systems, Generators, Batteries & Solar 1 07-13-2003 03:29 PM
