Old 11-06-2014, 04:16 AM   #1
2014 25' Flying Cloud
Keswick , VA
Alternative to Honda/Yamaha generators??
I recently saw this Generac generator in a local store and was intrigued by its much lower price compared to either of the "top" brands. I am shopping for a generator for my 2014 25' FC and was wondering if anyone had actually bought a Generac and what their experience was. Seems like it could power up the AC and do everything at a much lower entry $ of $589 with a two year warranty. Thoughts? Thanks for any and all imput.
Generac Power Systems | Portable Generator | iX Series | iX2000 | Generac Power Systems
Generac's iX Series 2000 Watt inverter technology takes the raw power produced by the generator and passes it through a special electronic microprocessor to provide clean and stable power, safe for computers and other sensitive electronic devices.
Features:
2000 watts of clean power to safely power sensitive electronics.
Electronic circuit breakers protect against overload.
Low oil shutdown protection prevent engine from damage.
FlexPower to save fuel and reduce noise.
12V DC charging outlet.
Control Panel Indicator Light.
Run time at 50% load 4.7 hours.
Emissions Certification: 49-State
herkvet is offline   Reply With Quote
Old 11-06-2014, 04:34 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have a regular Generac construction style generator... I have not been happy with a lot of the "features" they put on them. They have a tendency to be poorly designed and executed. Things like long plastic handles for a fuel shut off that stripped the first time it was used, feet that fold over if someone pushes on the generator, etc.
Another brand that is getting decent reviews is the Champion line of inverters generators. I have seen several of them first hand and at half the price of the Yamaha/Honda they are a lot of bang for the buck. One major issue is the small fuel tank size, and because they don't have a fuel pump using a extended run tank is a challenge.
I can sympathize with the cost of red or blue, they are expensive initially, however they seem to last forever with minimal added cost. I have a Honda construction generator that is almost 20 years old with over 4,000 hours on it still going strong. It still starts on the first or second pull, even after sitting for months at a time.
Aaron
WBCCI #XXXX AIR #2495
Old 11-06-2014, 05:05 AM   #3
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Previously discussed.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 11-06-2014, 05:05 AM   #4
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
We have a Honda 1000 Inverter model that we've used for several years to recharge the battery, etc. This summer, we bought a Ryobi 2200 Inverter model for a little additional capacity. It works well, and is very quiet. They have an extendable handle and wheels. The handle is a little on the flimsy side, so I expect that will eventually break. Overall, a good unit, at just over half the price of the equivalent Honda.
Roy
64airstream is offline   Reply With Quote
Old 11-06-2014, 05:38 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by Skater View Post
What he said.
Old 11-06-2014, 06:03 AM   #6
r carl's Avatar
Lin , Ne
Buy a generator that has a 3yr warranty.
Old 11-06-2014, 06:20 AM   #7
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Whatever brand or style (inverter vs. contractor) of generator you get, be aware that a 2000 watt unit will not run your AC properly. You might get the AC to start up using the 2,000, but there will be insufficient power and you will probably damage the AC unit. Some people run the 13.5 AC units with 3,000 watt generators but most people use a larger unit or a pair of 2,000's running in tandem.
Bob Martel
WBCCI# 5766
Old 11-06-2014, 06:22 AM   #8
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I have a Champion 2000W that I purchased at Sam's club about 3 years ago. Cranks the first pull and I have had zero problems. I paid a little less than $500 for it. It weighs just a few pounds more than a Honda but not much and is quiet. I see they now have a 3000W inverter model. I would have bought that if it had been an option so that I could run the AC.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 11-06-2014, 10:38 AM   #9
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Good Morning, Herkvet
Since you invested in a beautiful new 25' FC why look to cut corners now? Why not keep doing it right and continue to buy quality so you won't second-guess yourself down the road. I bought the 2@2,000W Honda units, and save weight by only taking the Companion with me to charge batteries, make early morning coffee etc during my spring, winter, and fall trips when I don't need AC. If you go that route, heed AnnArbor Bob's advice, tho. Jon
B00merang is offline   Reply With Quote
Old 11-06-2014, 02:57 PM   #10
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Have had two of the Champion 4000/3500 watt generators , they both start first pull 100 % of the time , will run the AC and microwave without a problem , will run a long long time on a tank of gas , the only drawback is they are noisier than the high priced Honda's. simply can't justify in my mind paying 2000. bucks if a 300 dollar unit will provide all the electricity we need .
dannydimitt is offline   Reply With Quote
Old 11-06-2014, 03:10 PM   #11
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
You can buy a Honda or Yamaha and use it for years and they retain their value whereas the off brands that you save a couple of hundred dollars buying are worth nothing (if they still even work).So being cheap (frugal)is more expensive and kinda foolish.
Old 11-06-2014, 03:58 PM   #12
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Regardless of what ever brand you choose, don't leave fuel in the tank and/or carburetor for extended periods. Both the Honda and Yamaha generators have a tendency to gum up fairly quickly (couple of months) when not used. Then you get to either tear down the carburetor, or have someone do it. I also recommend using a fuel treatment like Stabil.
Old 11-06-2014, 04:03 PM   #13
dznf0g's Avatar
Oswego , Illinois
I leave gas in my tanks all the time...over winter. I run the carb dry, and have Stabil as well as Chevron Techron in the gas....and yes , it IS 10% ethanol gas. Never an issue in any of my small engines. 2 strokes get Seafoam and Stabil.
(shouldn't use Techron in 2 strokes)
-Rich-
Old 11-06-2014, 05:51 PM   #14
2005 28' International CCD
San Jose via Winnepeg, Toronto, Orlando, Saratoga and Groton , California
Send a message via AIM to tyggeln Send a message via MSN to tyggeln Send a message via Yahoo to tyggeln
There's a thread on a Smart Tools Generator available at COSTCO. Doing a quick compare the Generac is about 5 more pounds, 400W more but no spec on noise, for the ~same price give or take 10 bucks.
Generac is a well known name and I would think its worth a look, especially if you can get it from a seller with great warranty and return service.
I'll probably go for the generator on sale at COSTCO (has a Yamaha motor) for just that reason. Looks like its available in CA too.
2005 28' CCD International
2x120W Solar Panels/22A GoPower Controller
1200# Equalizer Hitch
2007 GMC Yukon XL SLT
"Where are my keys?"
tyggeln is offline   Reply With Quote
Yamaha 2800 vs the Yamaha 2400iSHC gaylejoe Generators & Solar Power 14 04-30-2017 08:55 PM
Honda vs Yamaha Generators ROBERTSUNRUS Generators & Solar Power 115 06-13-2016 09:32 AM
Generators -- Honda 2000 vs. Yamaha 2400 Redcobra Generators & Solar Power 33 03-07-2011 11:12 AM
Honda EU2000 x 2 vs Honda EU3000 and Yamaha 3000 IntegrityAir Generators & Solar Power 43 07-01-2009 11:19 AM
Compare Kipor, Honda, Yamaha quiet generators side by side ShinyTwinkie Generators & Solar Power 17 09-26-2008 09:01 AM
