Old 11-03-2006, 09:39 PM   #29
Images: 59
Originally Posted by rama777
Actualy, one question, I was just looking at the manual for my converter and I can't tell if it's supposed to be grounded from to places or just one. The negative line seems to be grounded as well? Is that just for when you have a battery involved?
Seemed pretty clear to me. Did you get a different manual? Mine is 109205 REV L 10/02.
Here's what mine says:
CAUTION RISK OF FIRE
Chassis bonding wire must be a separate wire ran (sic) directly to chassis from the grounding lug provided on the side of the converter.
DO NOT connect Output negative to chassis using the same wire.
(endquote)
. . and the picture shows two separate ground connections.
Do you need a copy of the new manual?
Old 11-03-2006, 10:39 PM   #30
jemison , Alabama
Yeah it does show that. I guess I'll give it a double ground if that's what it says to do. As far as Zep saying to ground the negative, does that just mean that the fuse panel gets grounded? The panel I have has no negative spots, it only has four positions for grounding, so I plan on running the negative in there, and then using another grounding spot for an actual ground. Does this effectively ground my negative Zep?
rama777 is offline   Reply With Quote
Old 11-04-2006, 10:18 AM   #31
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
You can ground the negative at any point, from the converter to the fuse panel. The closer to the converter, the better, presuming it's a good ground point (eg, has good bonding to the shell, like through the skin and a vertical rib with a substantial connector, like a #10 screw and a ring or spade connector).
When I looked at the photo of your panel, it wasn't obvious that it had a set of negative terminals.
Zep
