Old 10-18-2006, 08:14 AM   #1
eureka , California
All ext. lights working except right brake/turn
I am having a bizzarre issue. All of my exterior lights (marker, license plate, left turn/brake) work when hooked up to my truck. However, the right turn/brake does not. If I connect a hot wire from my trailer's battery directly to the trailer plug it lights up. When I test the plug on the truck, the correct tab lights up my test light. But when put together, the right turn/brake light does not work. Any ideas?
grizz814 is offline   Reply With Quote
Old 10-18-2006, 08:19 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Sounds like the plug is not mating to the truck receptical. My marker/running lights do this. I have to plug it in several times to "clean" it. Maybe using a finger nail emery board to clean the contacts will help, or bending the contacts with needle nose pliers with fix the problem.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 10-18-2006, 09:27 AM   #3
2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
running lights
i'm having a similar problem. all my lights work except the running lights. i checked all the fuses, and then replaced the plugs. still no running lights. brand new dodge with tow package. any thoughts?
Kevbo10 is offline   Reply With Quote
Old 10-18-2006, 12:27 PM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Hot wire the lights first, not sure in a '05 what color wire it is at the fuse panel, mine was green.
If they lit, then it is the TV cable connection.
'77 Sovereign Intl 31' CB
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Rrunning Lights niftypkg Electrical - Systems, Generators, Batteries & Solar 7 08-22-2002 10:30 AM
Blinking Galley Lights ViewRVs Mechanics Corner - Engines, Transmission & More... 7 06-23-2002 08:42 PM
