Old 10-01-2012, 10:49 PM   #1
shadeemry's Avatar
1975 31' Sovereign
cary , North Carolina
Airstreams body shocks me plugged into shorline power
Just what the subject says, I used a circuit on all the outlets and they come back fine, why does this happen? Even if I'm in the trailer and touching the door it shocks the hell outa me, what should I start looking for to correct this?
shadeemry is offline   Reply With Quote
Old 10-01-2012, 11:04 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, the first thing that you should do is buy and use a little yellow polarity checker. Try it in the outlet that you have your trailer plugged into first.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-01-2012, 11:13 PM   #3
shadeemry's Avatar
1975 31' Sovereign
Hmm, that makes sense, just checked the outlet, have an open neutral?
Old 10-02-2012, 05:22 AM   #4
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
ZAP!
The circuit is being completed by you.
Old 10-02-2012, 05:54 AM   #5
1981 31' Excella II
New Market , Alabama
You need to look at your supply socket and see if it is wired correctly. Then work your way to the end of the pigtail and sockets inside the Airtream. Are all the sockets in the Airstream doing this or just one?
Perry
Old 10-02-2012, 05:55 AM   #6
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Always ground your trailer. Some part of metal on the trailer should be in contact with damp ground. No wood or plastic blocks under the jack or at least one of the stabilizers. I carry one of those $5 testers in my side door pocket and check the electrical before I spend the time to back into a campsite. Reversed polarity is the most common error.
Old 10-02-2012, 04:03 PM   #7
shadeemry's Avatar
1975 31' Sovereign
Originally Posted by overlander63
ZAP!
Thatnk you
Old 10-10-2012, 08:08 PM   #8
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
did you figured this mistery out?
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 10-10-2012, 09:20 PM   #9
1977 31' Sovereign
1989 34' Excella
Open nuetral
An open neutral would not make the trailer body to be hot. I would look for an outlet or place in the wiring harness that the hot wire has contacted the body of the trailer. An open neutral will cause the outlet to be non-functional unless the appliance has a defect where the internal neutral is shorted to the ground terminal.
Old 10-12-2012, 06:24 PM   #10
shadeemry's Avatar
1975 31' Sovereign
I think I got it, the 12 volts hot was crossed at the frame right by the power jack, this probably explained why the power jack was not working correctly, if at all.. I have not been shocked yet, but hopefully I won't be..scares the crap outa me to even touch the shell with it plugged into shoreline power. Is their a way to tell if the trailer body is hot without risking my life by touching it?
Old 10-12-2012, 07:35 PM   #11
1981 31' Excella II
Get a volt meter and put it on AC volts and measure the voltage from the ground to the skin of the trailer. It should not read more than a volt or two MAX. Stick one lead into the ground or better yet something you know is grounded.
Perry
Old 10-15-2012, 06:10 AM   #12
1977 31' Sovereign
1989 34' Excella
Switched polary on converter.
Unless there is also a defect in the univolt converter, reversing the polariy of the output should not make the trailer skin AC hot. You do need to disconnect the converter from the AC. In most trailers the univolt is actually plugged into AC with a conventional 110 plug. If it is not, you still need to get the converter out of the circuit to further isolate the problem. You will need a fairly good digital multimeter to do the job properly. I use a digital Fluke. It has a broad range with good readability down to .02 volts and good ohmmeter capability. After you get the converter out of the picture, retest the skin voltage. Make sure the soil is damp where you push in the negative lead. The skin should be less than .2 volts DC and AC. These are separate settings on the multimeter. You should also test it again after reconnecting the converter. If the voltage jumps up you have isolated the problem to the converter or connections. You could have the input voltage to the converter switched. That would also cause the problem since the internal AC neutral and DC neutral are interconnected within the converter. The next test would be to plug the little yellow tester into the place that the converter is plugged into to see if the polarity is switched there. If it is OK then you need to take the converter out and have it trouble shot by a certified electrician.
Old 10-15-2012, 08:11 AM   #13
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If you're plugged into shore power, the trailer's AC ground bus connects to the ground wire in the shore power cord, and from there back to the pedestal, which takes care of your AC ground without a separate ground wire to earth. Grounding the trailer frame to earth through a jack shouldn't be necessary as long as your shore power cable has a ground wire.
If you're plugged into a portable generator, same thing; your AC ground bus connects to the power cable's ground wire, and thence back to the generator. This is why a portable generator should be grounded to earth when it powers your trailer. Most people don't ground their generators, though, according to responses I've seen on other threads.
It's only different when you're making AC power through an inverter from your house batteries. There, you need to ground the trailer through a separate metal-to-earth connection, since the shore power cord's ground wire isn't there to make the connection to earth for you.
Cats and ultraleather Airstream upholstery don't mix!
Old 10-22-2012, 06:08 AM   #14
1977 31' Sovereign
1989 34' Excella
There is always the possibility of something being improperly electrically connected. The result can be really bad, if not fatal. WBCCI has a rule that all trailers must be grounded when they attend a rally. It is a good rule. Better safe than sorry is my motto.
