Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-23-2009, 09:18 AM   #1
Profile:  1966 26' Overlander
Bemidji , Minnesota
Smile Airstream Shock!
I have a 1966 Overlander...all electrical is working including both 12 volt and 120 volt systems...however when I touch the outside of the trailer while standing barefoot on grass I get shocked....less than 120 volts I think but still uncomfortable....can someone help me fix this..thank you
mmario is offline   Reply With Quote
Old 09-23-2009, 09:31 AM   #2
SteveH's Avatar
Profile:  2001 25' Excella
San Antonio , Texas
I would estimate there is a bad ground on the AC system. Double check the GREEN wire on the AC cord to prove that it does go to chasis ground on your trailer.
Old 09-23-2009, 10:53 AM   #3
Minno's Avatar
Profile:  1972 31' Sovereign
Lexington , Minnesota
Or a bad ground on the outlet you're plugged into.
Old 09-23-2009, 12:05 PM   #4
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
go the the searh tab and put "hot skin" in the google search. it's potentially lethal and may be reversed polarity.
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 09-24-2009, 08:49 AM   #5
Bemidji , Minnesota
The ground I was plugged into was bad...just changing outlests worked!!!! Thank you so much!
shock mounts tebone Land Yacht/Legacy Motorhomes 4 12-20-2008 04:19 AM
Shock replacement dmadam Shocks 29 09-30-2008 09:55 PM
Electrical shock randallmiller General Appliance Topics 9 12-27-2003 02:56 PM
Shock time Dbraw Shocks 5 03-08-2003 05:04 PM
63 TW shock Moonshot Shocks 5 08-26-2002 10:24 AM
