04-15-2011, 08:38 AM
Littlefork
Airstream Central Control Panel
My central control panel above the kitchen sink seems to have blowen a fuse or shorted out. I installed a 12V Deep Cycle battery and all functions were working on the panel. Then I turned on the water pump at the panel and everything went dead. However, the 12V interior lights still work. I cannot find a fuse or circuit breaker that is blown or tripped. Anyone have any ideas where the problem may be?
04-15-2011, 08:47 AM
Airstream - Other
Bosque Farms
, New Mexico
Hello, there, and welcome to the forums! I'm sure you'll find plenty of other owers here willing to jump in with some advice on the problem you've encountered with your Airstream! (I would, too, but our Airstream -- a 67 model -- surely doesn't have the same electrical design as yours.)
Again, welcome to the forums!
Lynn
ACI Big Red Number 21043
04-15-2011, 08:55 AM
1968 24' Tradewind
Oxford,
, Mississippi
Had to say hi and comment on your forum name. I live about 50 miles from the "crossroads". Hwy 61 and Hwy 49 intersection in Clarksdale, MS- home of the delta blues.
Good luck on solving your electrical issue. My 68 is different so I can't offer any advice.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
04-15-2011, 09:01 AM
1978 31' Excella 500
Venice
Look in the fuse panel down by the battery charger under the front window. Also check the battery is hooked-up with the correct polarity.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
04-15-2011, 09:23 AM
x
XXXX
, XXXX
Deltablues11 there is a fuse on the back of the central control panel. You will need to remove the face to get at it.
04-25-2011, 09:03 AM
Littlefork
Okay, I've looked over that Central Control Panel and find no way of removing the face to get inside of it. It is surrounded by the overhead cabinet above the stove and is part of the stove fan assembly. I've taken the fan filter off to see if I could come from the bottom and it is also sealed. What am I missing here? Anyone have any ideas?
04-25-2011, 09:46 AM
Milford
, Ohio
Does your control panel look like this? If so I know a lot about repairing these.
Christopher
04-25-2011, 11:38 AM
1977 27' Overlander
Trotwood
, Ohio
I'm have the same problem as Delta . I need to replace all the bulbs I think. I also tried goin in from the bottom NO LUCK. Mine is different than what you have pictured. MINE is all windows. I NEED HELP TOO!
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
04-27-2011, 01:23 AM
2019 23' Flying Cloud
Santa Barbara,
Control panel
Can anyone tell me if there is supposed to be a CP on a 66 Safari?
I see no signs of one, and am wondering how to manually check all systems without it. I gather that it might be (or supposed to be ) over the galley in the cabinet.
Any help here would be greatly appreciated, original available, or any to recommend that are better?
John
04-27-2011, 07:00 AM
Airstream - Other
Bosque Farms
, New Mexico
The CP on a 66 is probably like the one on our 67: Not much there. It's basically just a switch for the water pump and the thermostat for the AC. None of that fancy stuff like on the newer rigs!
Lynn
04-27-2011, 09:43 AM
Santa Barbara,
Thanks- Yes, I have those 2 things-although it has no A/C-just a furnace that I haven't tried. I'm thinking about removing the innards and re configuring it with a wave 6 catalytic heater- recessed if it will fit.
How do you check/monitor your black tank level, and fresh water level for that matter?
John
04-27-2011, 10:06 AM
Ottawa
, ON
John
As for the black tank, a small flashlight is all you need.
As for the CP vs. all storage tanks, the accuracy of those meters on the CPs (when they work, prone to failure if you read up on them) is in great doubt.
Even the newest ones don't seem to be anywhere approaching 100% accuracy or reliability.
04-27-2011, 10:35 AM
1974 27' Overlander
Sault ste Marie
, Ontario
If you can remove the small side panel on the right side of the control panel, you may be able to get at the fuse holder. My 74 mtc. manual lists it as 15 amps and it's on the blue wire. Failing that you have to take the whole thing out. This is done by removing the exhaust filter, the filter bracket, the afore mentioned side panel, the knob for the exhaust, unplug the wiring harness, and weasel out the control panel. Good idea to clean the harness plug contacts while you have it apart. Good luck!!!.......Phil.
05-29-2011, 08:29 PM
1978 31' Sovereign
Cookeville
, Tennessee
i have a control panel like the one here in post #7. it works from time to time. right now if is not working. I press the button and a quick flash of lights but doesn't stay on long enough to read the levels. Any ideas how to fix this?
05-29-2011, 08:46 PM
Ottawa
, ON
One of many things it could be is corrosion in the "Panel Display" switch.
Several good shots with a very good contact cleaner on the innards of that switch might bring it back into play.
I have to say though, I don't have much faith in those panels. Lots of wires, a zillion contact points, put it all together it calls for more maintenance than most people are willing to give just to have so-so accuracy of things that are much more precisely checked with either a VTVM or a flashlight.
Your mileage may vary, of course...
06-22-2011, 09:17 PM
1978 23' Safari
eugene
, Oregon
I have a 78 23 foot. The furnace fans and the pump are on the pink wire on mine.
06-22-2011, 09:19 PM
1978 23' Safari
eugene
, Oregon
once I tightened up the sensor screws (phillips) my control panel worked fine
01-27-2013, 08:01 PM
1978 31' Sovereign
Cookeville
, Tennessee
my panel looks like yours. I need to replace the panel display push button. Any advice?
01-28-2013, 08:02 AM
1978 23' Safari
eugene
, Oregon
I have no advice but I do have a maintenance manual I'll sell you. My safari bit the dust not long ago. Email me if you are interested. tunod81@yahoo.com
06-25-2014, 09:22 AM
1971 31' Sovereign
Lake Minnetonka
I'm having a similar issue once i installed a new water pump, I have checked and rechecked every fuse, I am lost. All my electronics are working except for the control panel, and really the only thing I need from it is the water pump.
