Old 02-03-2014, 06:52 PM   #1
Firedog1
Firedog1's Avatar
2018 30' Classic
Woodbridge Connecticut & , Venice Florida
Air compressor recommendation needed
I want to carry portable air compressor for emergency, any suggestions? 12 volt or electric? I do have honda 3000 generator in my truck if electric is way to go. appreciate some advise. Thanks
Firedog1 is offline   Reply With Quote
Old 02-03-2014, 07:01 PM   #2
BeachHouse's Avatar
2005 25' International CCD
Lilburn , Georgia
We have the Ryobi air compressor and the Ryobi 18v drill to adjust the jacks and stabilizers. We love it
BeachHouse is offline   Reply With Quote
Old 02-03-2014, 07:11 PM   #3
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
We picked up a fairly beefy unit for little $ at a WalMart on the road. It claims to be for 'Big' tires and had no trouble getting the tires up to 60 Lbs. on a mountain, and included a nice case and some plugs and tire "Goo". It was the most expensive one at Walley World but that is still cheaper than the cheapest at Camping World. If this will not do the job I call 'AAA RV'!
captmatt is offline   Reply With Quote
Old 02-03-2014, 07:18 PM   #4
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
BTW, it is a 12 v. unit and it is small enough to slide under the seat in the TV but not too small that you forget were it is.
Old 02-04-2014, 12:42 AM   #5
K9CarCrate's Avatar
2014 Interstate Ext. Coach
Vienna , Virginia
PORTER-CABLE CMB15 150 PSI 1.5 Gallon Oil-Free Fully Shrouded Compressor
PORTER-CABLE (97)
I think this compressor is awesome. I can use it to fill tires, winterize the RV by blowing the water lines, and I have an attachment to blow air if I need to dry something. Bought it on Amazon.
K9CarCrate is offline   Reply With Quote
Old 02-04-2014, 01:16 AM   #6
Mexray's Avatar
1978 28' Ambassador
Morada , California
I've used one of these for several years...It comes in a hard plastic case...
12 Volt, 150 PSI High Volume Air Compressor
I installed a Male 12 volt type plug on the end, replacing the clamps, I then installed a female 12 volt plug on the wires from the clamps as a 'adapter' in needed...
Ray & Pat; Morada, CA
Old 02-04-2014, 08:17 AM   #7
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
I have the same one but came with a cloth case. It's a big big improvement over the old Coleman's.
Ahab is offline   Reply With Quote
Old 02-04-2014, 12:04 PM   #8
dznf0g's Avatar
Oswego , Illinois
I have one very similar to Ahab's. Check in with the off-road jeep forums for a lot of discussion on the 12 volt units. They use and modify them heavily.
-Rich-
Old 02-04-2014, 01:51 PM   #9
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Viair
This is what I bought: VIAIR 450P Automatic Function Portable Compressor : Amazon.com : Automotive
After my research, this is what I determined to be the best that I could buy. I wanted one that would never fail and had no duty cycle, that is, could run continuously.
The HF unit is obviously a good price but the manual says nothing about duty cycle. My experience with HF stuff is that it is cheap and will work, but is not well made for the long term.
Larry
lsbrodsky is offline   Reply With Quote
Old 03-19-2015, 10:48 AM   #10
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Anyone have experience with Viair units enough to know how well this one would work? Thinking of something for LT tires. 80-90 psi.
http://www.amazon.com/Viair-00088-88.../dp/B005ASY23I
SCOTTinNJ is offline   Reply With Quote
Old 03-19-2015, 11:59 AM   #11
Edistobob's Avatar
2013 25' Flying Cloud
Edisto Island , South Carolina
Bought one of those in late 2012 to use both with the trailer tires and the TV tires (275/55 R20). It does an excellent job, doesn't take too much time to fill the larger tires and seems to be very well built. I don't hesitate to recommend it to people who want a good 12-volt pump that does not take forever to fill the tires.
Edistobob is offline   Reply With Quote
Old 03-19-2015, 12:59 PM   #12
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Ditto on the Viair 88P. I use it on both the trailer and TV. My nephew bought one at the same time to use on his offroader to air up his 33 in. tires and is also happy with it.
George
gandttimes is offline   Reply With Quote
Old 03-19-2015, 01:33 PM   #13
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I just installed a Viair 400c, real happy with it.
mayco is offline   Reply With Quote
Old 03-19-2015, 01:41 PM   #14
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Thanks all.
Compressor recommendation? rfield54 Fresh Water Systems 17 10-27-2013 06:19 PM
Portable Compressor Recommendation wlanford Tires 4 07-14-2011 08:29 PM
Armstrong compressor needed lexusparts Furnaces, Heaters, Fireplaces & Air Conditioning 5 03-22-2009 07:11 PM
Compressor ideas needed .... Help! GlenCoombe Mechanics Corner - Engines, Transmission & More... 16 05-01-2008 09:45 AM
air bag air compressor dbyar Mechanics Corner - Engines, Transmission & More... 12 05-08-2004 12:58 PM
