Old 03-22-2017, 10:03 PM   #1
2017 25' Flying Cloud
1964 17' Bambi II
Ogden , Utah
AGM Battery
We are in the process of purchasing a 2017 25' FC. The new Airstream comes with the two Interstate batteries. We are thinking of purchasing two AGM batteries instead. We're wondering if it is worth the extra expense to go with these batteries. We understand they are maintenance free & they hold a charge & recharge better then the Interstate batteries. What are the pros & cons. Thank you for your input.
mcaslaon4449 is offline   Reply With Quote
Old 03-22-2017, 10:54 PM   #2
Granbury , Texas
Unless you plan to do a lot of boondocking or use solar the factory interstate batteries are fine.
In a few years when you need new batteries then replace with what you want.
Be aware that the factory 12 volt converter will overcharge your batteries and might ruin those AGM's.
Before I went to those I think I would replace the converter with a upgraded one that cycles the charge as needed.
When camping the factory converter isn't too big a deal because your regularly using 12 volt power. During storage I strongly recommend against leaving the Airstream plugged in to shore power because the converter will overcharge and boil your batteries.
Use a "Battery Tender" or "Battery Minder" like you see mounted on boats. These will charge the batteries then float charge as needed. Your batteries will thank you and last many years.
Don't forget to check the water especially in hot weather and top off with distilled water as needed.
cabinetmaker is offline   Reply With Quote
Old 03-22-2017, 10:58 PM   #3
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
AGMs cost more and are reported to have a longer life. AGMs are also safe to be moved inside the coach to reduce tongue weight. In that position, larger battery size is also possible. The other advantage of AGM is the ability to discharge the bank to less than 50%. However, they have been known to die at less than the expected life span that makes them cost effective. Only you can determine if the cost of an AGM house bank is appropriate for your RV application.
We gave it some thought and ended up keeping the Interstates. We normally use full hook up RV parks, so bank capacity is of minimal concern. We have decided to use a LPG generator for the rare opportunities when we will dry camp.
You should look at a battery disconnect for storage, a converter upgrade for multi-stage charging, and a monitor for power management.
Good luck with your choice. Pat
Old 03-22-2017, 11:24 PM   #4
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
AGM's are the best. No maintenance at all. Be sure to upgrade to SmartCharger. Also the deeper battery box that Airstream now uses will accommodate two high amp AGM's.
TinCan
graysailor is offline   Reply With Quote
Old 03-23-2017, 08:02 AM   #5
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Discharging AGM batteries below 50% is not recommended. It will shorten their life. You can check this with a battery monitor kit. Talk to Randy at Bestconverter.com. He is an expert and can recommend the right equipment.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 03-23-2017, 08:56 AM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Are you an experienced camper who knows how they like to camp? Or is this basically new to you and you still don't know your "camping style?"
If you are an experienced dry camper (or boondocker if you prefer) then switching to AGMs right away makes sense. However, if you are new to this you may find that camping with electrical hookups is more your style in which case investing in AGM up front may not make as much sense.
Frankly, I would start with the Interstates and see how you end up using them. You can always spend the money for the AGMs down the road.
In any event, the first thing I would do is replace the Airstream supplied charger with a multi-stage (or smart) charger. Regardless of whether you use wet cells (Interstates) or more expensive Lifeline AGMs the stock charger will kill them in short order so the charger upgrade it a wise investment.
Finally, as previously corrected, AGMs should not be run below a 50% charge (about 12.2 volts at a resting state) or you risk damaging them as you do with wet cells.
Bob Martel
WBCCI# 5766
Old 03-23-2017, 09:46 AM   #7
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
We (and the rest of our unit) do a fair amount of boondocking, but I'm an irrational cheapskate. I say irrational, because if I were a rational cheapskate I probably wouldn't have bought the new 26U I'm going to fetch in a little over a week...
At any rate, I thought about this. If the flooded Grp. 24s turn out to be in good shape when I go to get the 26U, I'm going to use them 'til they drop and then replace them with AGMs. If they aren't in good shape (I'll be camping in the trailer on battery power the first night as a test) then I'll negotiate a credit towards AGMs instead of a swap to new flooded batteries.
I camped with a single (!) grp 24 in our vintage trailer for years, and could go several days without charging but all it was really driving was LED lights and the water pump. The new trailer has gadgets I'll want to use, and 12v control boards in the fridge and water heater and a propane detector that'll use battery capacity even when I'm trying to conserve. Even the toilet is electric!
David
DKB_SATX is online now   Reply With Quote
Old 03-23-2017, 12:57 PM   #8
PKI
PKI's Avatar
My apology for the greater than 50% discharge statement. That was an error as additional discharge reduces life. Thank you all for correcting the thread. Pat
Old 03-26-2017, 09:13 AM   #9
Chelsea , Michigan
Images: 12
I assumed you were thinking of Lithiums when you made that comment.
Bob Martel
WBCCI# 5766
Old 03-27-2017, 10:02 AM   #10
PKI
PKI's Avatar
No, it was my understanding that AGMs could be discharged below 50%. I broke one of my principle internet rules - "do not believe what you read without verification".
After seeing the correction in this thread, I did some basic research, which I should have done earlier, before providing incorrect information.
The Lifeline manual has a life cycle chart in the appendix. It shows the degradation in battery life with respect to discharge level. Degradation starts at 5000 cycles if the battery is only discharged 10% and goes down to 500 cycles if discharged 85%. The 50% discharge level yields a 1000 cycle life. So even going to 50% has a significant impact on life.
Thanks to all for correcting my prior error. More research pending. Pat
Old 04-01-2017, 09:41 AM   #11
Chelsea , Michigan
Images: 12
No, it was my understanding that AGMs could be discharged below 50%. I broke one of my principle internet rules - "do not believe what you read without verification". Pat
There is indeed a lot of misinformation on the internet. And an amazing amount of misinformation even on AirForums! Fortunately, on AirForums I believe that those who misspeak have the best of intentions but are simply misinformed and just passing along what they believe to be the truth.
As some say: all information is worth precisely what you pay for it.
Also, I think that Ronald Reagan was quoted (or perhaps misquoted?) as saying: Trust but verify!
Bob Martel
WBCCI# 5766
Old 04-01-2017, 10:03 AM   #12
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
AGM's
We had "bad" Interstate batteries when we purchased our 2014 new. Took us a couple trips to figure out why things were not working right...some of the 12vdc lights and water pump worked, and some did not, including intermittent stereo issues. Found out we had bad cells in the "new batteries". Interstate offered to swap them out free, since they come with a 3 year warranty. They also offered to give me 100% credit on AGM's, which they recommended. We went that rout and 2.5 years later, we have had no issues. I would stay with the original equipment till they fail, then make your decision. I would also look at some folks recommendation for 6V's, or Lithium also...in the end, its just money... We used original equipment 12V's in our first 2 AS's and never had an issue, so it really can vary on this.
Old 04-01-2017, 11:25 AM   #13
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Pretty sure interstates that airstream uses come with a 12 month warranty. Which is why I was out of pocket when mine died at 13 months.
Mike
Caffeinated is offline   Reply With Quote
Old 04-02-2017, 08:25 AM   #14
gypsydad's Avatar
Mike
You may be right; could have been 12 month warranty, but Interstate did give me the credit toward the AGMs. If I had the room, I may look at those 6 V deep cycle they offer.
I just remember that when I took in my AS to the dealer after only owning it for 4 months with the "electrical issues", he had it for 3 days before they discovered the battery would not hold a charge and got Interstate involved. They tried to charge me for labor to trouble shoot the problems and also tried to charge me mileage to Interstate till I complained to the owner. I went to Interstate myself and got them to swap the batteries to the AGM's with full credit; no issues from Interstate. They recommended the AGMs at the time. I might look at their 6V models if I had room in my box up front, but these AGMs have worked fine for 2+ years now.
Battery AGM (4) 6V GC2 vs (2) AGM 8D Torpedo Family Land Yacht/Legacy Motorhomes 3 11-15-2012 05:35 PM
Battery vent - or AGM pauly g Batteries, Univolts, Converters & Inverters 15 01-23-2008 08:32 AM
Deka Sea Mate AGM Battery Stream 1529 Batteries, Univolts, Converters & Inverters 4 07-27-2007 12:08 AM
New Progressive Dynamics convertor, AGM battery, and Pendant questions wacnstac Batteries, Univolts, Converters & Inverters 16 05-09-2007 09:12 PM
AGM battery question LuminumTraila Batteries, Univolts, Converters & Inverters 3 03-01-2005 04:56 AM
