Old 06-13-2013, 01:29 PM   #1
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Adding separate 30 amp service
I am looking for a parts source. I want to install a separate breaker box, and wiring for some extra circuits. I am having trouble locating the power cord receptacle mounted to the trailers exterior, and a breaker box like the existing one from Square D in our 1997 Airstream. I would like the exterior plugin to be like the new trailers with the chrome/marine type.
The purpose it to provide power for a second A/C, the electric side of my water heater, and a new electric radiant floor heat system.
Thanks in advance
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 06-13-2013, 02:51 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Go get a Marinco type inlet. Then a small breaker box...usually 4 will be the smallest.....any electric supply will have it. Then circuit breakers for the box....I use double ones so I can have eight separate circuits. Make one a 30 amp for the master inlet source. then 12 x 2 romex to your outlets.
Old 06-13-2013, 03:02 PM   #3
Images: 59
Here is a source for the Marinco Inlet. You can also find them at most marine stores and sometimes Camping Whirled.
Old 06-14-2013, 12:53 PM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
Thank you
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 06-14-2013, 01:35 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Would this be legal and safe? I'm thinking of two separate services, and say one is to campground power and the other to a portable generator. Not that you would, but that someone could.
Separate potentials, neutrals, grounds within a metal trailer doesn't sound good to me.
doug k
