Old 11-19-2007, 07:11 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Adding interior 12v electrical connections
I would like to add a propane detector, CO detector and a 12v outlet to my 71 Tradewind. An easy place and good location for me to mount them is the front of the galley sink cabinet. I can splice into the existing 12v line that goes to the furnace. The 12v outlet would be used occassionally for low draw appliances such as cell phone, dvd player or small flat screen tv. Anybody see any problems with this idea or have any better ideas?
Old 11-19-2007, 07:20 AM   #2
Central , Mississippi
I'd do a temporary hookup and give it a try with the loads you expect to use. I had a heater that was pickey about voltage level and wouldn't run properly if the voltage dropped. Any extra load on that circuit would prohibit the gas valve from opening so it would misfire. My current one seems to be much more forgiving.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
12v
Electrical connections getting hot wardster All Argosy Trailers 23 09-25-2007 03:44 PM
Need suggestions on Interior 12V Lighting. Argosy man Lights - Interior & Exterior 5 09-10-2007 04:56 PM
12V Electrical Questions Airstream 65 Batteries, Univolts, Converters & Inverters 4 06-07-2007 03:24 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
Interior Picts Electrical campcollector 1997 - 2004 Bambi 14 04-21-2004 02:09 PM
