Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 03-08-2003, 07:18 AM   #1
Jabba's Avatar
Profile:  1955 30' Liner Commodore Vanderbilt
Wayne County , Michigan
Adding charger where no charger has gone before
Ok, seeing the posts on Univolt, Intellivolt etc. I have a similar but different problem. I'm new to this and am not versed in the electrical transfer arts, our '55 has 110V and a 12V system, completely seperate from one another. There is no means of charging the battery while plugged in to shore power other than removing the battery box cover and attaching a normal charger (which I found 2 of in the trailer). What would be the recommended means (and type) of installing a battery charger/maintainer?
Jason & Veronica J.
S.E. Michigan
1955 Commodore Vanderbilt 30'
"Hawley"
TAC Member MI-6
2008 Chevy Silverado Ext. Z71 w3.73
Jabba is offline   Reply With Quote
Old 03-08-2003, 07:24 AM   #2
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Not sure about how the '55 works, but I gotta believe that there is something a bit easier (not that connecting a charger is hard).
John HD might have a few suggestions.
Does you unit charge off the car when connected. Just a question for my personal knowledge about the older units with your type of electrical systems.
Regards,
Eric
Old 03-08-2003, 07:46 AM   #3
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
Question who me?
jason
the first thing you would need to decide is where to put a univolt or intellipower unit.
as close to the batteries would be best.
then getting a 120v supply would be next.
after those problems are addressed, you will need to make a 12volt buss. that will be needed to provide fuse protection.
john
Old 03-08-2003, 08:36 AM   #4
Jabba's Avatar
Unhappy Huh?
Yes, the battery will take a charge from the tow vehicle. Next, what's a buss? Please forgive my ignorance. There is some sort of terminal block seperate from the fuse block on the 12V end of things. The battery is in a box hanging from the front of the trailer over the tongue. The 12V fuse block and all the connections related are under the front couch along with the water pump and water tank. Which is accessed by removing the drawers or pulling the couch apart (fun). Does the chrge line run directly to the battery or what? John, I've been told a Digital camera is on the way for my upcoming birthday, so I'll be able to start snapping some pictures like you asked.
I'd be concerned with the amount of noise (if any from the charger) and I've heard that some of the chargers have to mounted vertically?
Jason & Veronica J.
S.E. Michigan
"Hawley"
TAC Member MI-6
Old 03-08-2003, 09:39 AM   #5
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
get on the buss
jason
a buss i just a common bar that allows you to connect all your leads in one convienent spot.
you very well may have one now, so adding one may not be needed.
the charge lines from your tow vehicle or a future univolt would go right to the "buss" or fuse block.
when is your b day? pictures will help alot!
under your couch would be an excellent spot for your charger/univolt, as it is close to the battery.
as for the sound, you can always turn it off before you turn in for the night.
john
battery charger ALANSD Batteries, Univolts, Converters & Inverters 8 09-16-2007 05:52 PM
Adding a fan to the fridge Stefrobrts Refrigerators 31 04-10-2004 06:07 PM
Converter/battery charger ARGONUT Batteries, Univolts, Converters & Inverters 0 11-23-2003 04:28 PM
Solar Charger Sneakinup Generators & Solar Power 1 10-07-2003 09:04 AM
Trickle charger to replace Univolt jwaldin Electrical - Systems, Generators, Batteries & Solar 2 02-18-2003 10:12 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
