Old 02-26-2010, 11:29 PM   #43
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
maniacs on the loose. water heater has its own switch. most of the dc wall switches you find in an rv are rated for 7.5 amps , you would be hard pressed to find an ac switch rated at 7.5 amps as basic is 15 amps. and why would you ?????????????????????????????
for water heater 120 vac service add aux box with 12 gauge 30' cord, would allow you to plug in water heater without using 12 of 30 amp service that way you can run your water heater electric and still use your ac and converter without blowing service breaker. this is a common industry answer to aftermarket 120vac waterheater on 30 amp rv.
crestonrv is offline   Reply With Quote
Old 02-26-2010, 11:35 PM   #44
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
afterthought; you could add a motor base (male plug in socket,exterior wall mountable)that way the extra cord could be easily stowed when not in use. or just route in with shore cord and coil in trunk.
Old 02-27-2010, 02:27 PM   #45
joqin's Avatar
1965 17' Caravel
brooklyn park , Minnesota
12V vs 120V switch use
thanks all of you for your answers. I will read the back of the switch before I install it. If you ever drop by MN in Jan.(HA-HA), I owe you a bowl of ice cream. We`eat that to warm up when we come in to warm up!!!!!!!!!!! joe q in Minnesnowda
joqin is offline   Reply With Quote
Old 03-10-2010, 08:06 PM   #46
2xS
2xS's Avatar
1971 31' Sovereign
San Diego , California
Hey Gen,
I just did this with a tankless water heater demanding 40A. Your system requires 120VAC @ 1400W. The Ohm's Law equation, I = P/E confirms that your water heater will need 11.67A, RMS of power for operation: I = 1400W/120VAC.
If I was you, I'd go purchase a single pole <manufacturer specific> 15A breaker to install in the box; this will protect your water heater. Now you will need to add the circuit. Run a new wire (12-2 gauge will be plenty, "mc-lite" cable preferable for outdoor locations) from the water heater to the distribution box, and then connect: white to the white common, copper or green to the ground common; then connect the black cable to the output of the breaker, and plug it in. I see someone has already tied in the second breaker position with that red wire in your photo of your box so that should be all you need to have your power on the other end where your water heater is. Follow their instruction for connection, and you'll be up and running in no time.
Adding an additional load of <12A at the distance you are stretching it should not be an issue. At worst you'll blow the resettable GFI outlet or park breaker if they aren't supplying enough current to meet your demands. You won't trip anything on your end. To manage that feat, you'll need to have everything on: your AC, your water heater, microwave, chargers, a vaccuum, and then probably a other things...
If you are truly worried about it... all you would have to do is run a new beefier cable to your distribution box; a 6-2 nmb should do ya.' Kirchoff's current law reveals the additional current load would only be exuded by your trailer plug in cable and no where else; aka just because you add a 12A device doesn't mean it will affect any other wiring in the trailer. This, of course, won't solve the problem if you are demanding more than 30A of service, but even with your water heater system installed, you'll have to try pretty hard I think...
Lasciate ogne speranza, voi ch'intrate
2xS is offline   Reply With Quote
12 V outlet BillTex Lights - Interior & Exterior 4 09-28-2008 12:33 PM
Adding Exterior Outlet Ganglin Lights - Interior & Exterior 4 09-18-2007 09:27 PM
Adding a 12VDC outlet outside?? myoung Electrical - Systems, Generators, Batteries & Solar 6 08-25-2006 05:42 PM
T V outlet Gene Wissink 1974 - 1979 Sovereign 0 01-19-2004 07:56 AM
Electical outlet Alex Electrical - Systems, Generators, Batteries & Solar 3 11-30-2003 08:50 AM
