Old 03-21-2017, 08:17 AM   #1
Mr Happy's Avatar
2013 16' Sport
Minneapolis , Minnesota
Adding an extra battery
Hi there,
I have a 2013, 16 foot, Sport, Bambi...
I am wanting to change my onboard battery from one battery to two and looking to go with AGM. When I add an additional battery will I need to change anything else in the electrical system? Will it affect my solar panel in any way?
Also, I want to add a brighter light next to the door, on the Bambi there is just a very small step light and I was wondering if I could add a brighter light at eye level and run it off the same switch?
Thanks very much!
Mr Happy is offline   Reply With Quote
Old 03-21-2017, 08:49 AM   #2
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Easy
As long as you have space, wiring up 2 AGM's in place of your stock battery should not require any other mods. Do you have a good (multi stage) converter? If not, you should get one regardless.
Change out the bulb for a bright LED and you will get more light with lover current draw. No other changes required.
BambiTex is offline   Reply With Quote
Extra Sprinter chassis battery under hood. curmugeon Sprinter and B-van Forum 9 07-21-2015 01:32 PM
Extra, Extra!! codybear Airstream "In the News" 3 04-16-2007 03:59 PM
Adding second battery box nickcrowhurst Electrical - Systems, Generators, Batteries & Solar 5 02-13-2004 05:26 PM
Adding a second battery... drboyd Electrical - Systems, Generators, Batteries & Solar 3 07-28-2003 12:45 PM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 01:03 PM
