Old 03-31-2010, 05:05 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Adding an Exterior 110v Outlet to my Sovereign
I want to add an exterior 110v outlet to the curbside of my Sovereign. Has anybody else done this? How about to a 70s Sovereign? If you have, how did you go about doing it? Did you just tap into an existing outlet? Where did you mount it?
I have a 110v outlet at my curbside storage compartment that I really don't use. I was thinking about removing this outlet and mounting the exterior outlet near the storage compartment door and using this wiring. Thoughts on this approach??
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 03-31-2010, 06:13 PM   #2
Images: 59
I added a 120V outlet to my '59. I wanted to use a single right angle twist lok receptacle with a short cord that would lay flat against the side of the trailer.
There aren't any twist-lok GFCI outlets available, so I put a feed through 20a GFCI on the inside and wired through it to the nearby outside twist-lok.
I think you could do the same. Just replace the outlet in the curbside with a GFCI, and extend the wiring to the exterior outlet fitted with a nice weathertight cover.
Old 03-31-2010, 06:47 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
AS put it on the ground fault circuit from the bathroom, on our MH.
Old 04-01-2010, 12:39 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks Mark and Dave.
No other responses to this thread? I'd love to get some feedback from those who've done this modification to a 70s model, especially a Sovereign.
1958 Overlander
4CU 1st VP
Old 04-01-2010, 01:46 PM   #5
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Mike, Ours has an outlet on the outside. I always thought it was factory installed. It is near the rear access door behind the wheel well. Want a picture? The trailer is here at the house for another day while I install the new fantastic fan in the bathoom and pull out the screen frames to paint and replace screens.
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 04-01-2010, 01:55 PM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Yes, Mike, I'd love a pic. That's exactly where I was thinking about installing mine.
If yours is factory, your Sovereign would be the first '72 I've come across.
I did the screen work last week. Painted one, sanded the paint completely off another, installed several screens, and bug proofed a few more.
1958 Overlander
4CU 1st VP
Old 04-01-2010, 02:17 PM   #7
Elkhart , Indiana
Talking
Here are a few shots. The first is outside location of ours. The second shows where it ends up on the inside. (you could move it back a little to clear that wall ((it is the head of the bed/ closet wall)) the third is where you COULD put it (Green tape) and have the wires run from the same line as the Univolt power. (ours is now Intelli power) if you take the floor out of the closet you will have enough room to work on the inside (that would put it between the tape and our existing outlet. THERE IS POWER UNDER THE TUB to tap into. I hope this helps a little.
ID:	99218   Click image for larger version
Mike
Have a great day!
Old 04-01-2010, 02:38 PM   #8
Elkhart , Indiana
this may help also
Mike
Have a great day!
Old 04-01-2010, 02:49 PM   #9
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Awesome! Thanks, Mike, for the pics!
1958 Overlander
4CU 1st VP
Old 04-01-2010, 04:13 PM   #10
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
When are you going to attempt this installation? I may be available to assist.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 04-01-2010, 04:21 PM   #11
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Cool, Brad. I'm going to tackle this Saturday morning.
1958 Overlander
4CU 1st VP
Old 04-01-2010, 04:24 PM   #12
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Should be doable. You have all the parts you need? I have a some 12-2 and 12-3 wire if we need it. I'll call you.
FF
Old 04-01-2010, 06:29 PM   #13
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I think I'm good to go. I'll PM you.
1958 Overlander
4CU 1st VP
Old 04-01-2010, 06:47 PM   #14
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Just a reminder to those of you who saw this earlier thread on the subject. This is the outlet cover I'll be using.
http://www.airforums.com/forums/f44/...t-60878-2.html
1958 Overlander
4CU 1st VP
Adding an outlet Boondocker Electrical - Systems, Generators, Batteries & Solar 45 03-10-2010 08:06 PM
Microwave 110v power outlet location? SnoSheriff Stoves, Ovens & Microwaves 1 07-24-2009 12:46 PM
Exterior outlet RLS Electrical - Systems, Generators, Batteries & Solar 10 06-22-2009 10:37 AM
Adding Exterior Outlet Ganglin Lights - Interior & Exterior 4 09-18-2007 09:27 PM
Adding a 12VDC outlet outside?? myoung Electrical - Systems, Generators, Batteries & Solar 6 08-25-2006 05:42 PM
