Old 04-01-2010, 08:09 PM   #15
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
Mike all 3 of my AS's have the outlets outside. And I'm sure they are factory. They are chrome. The 83 and the 73 have duplex and the 69 has a single outlet. ODMRV has a single and vintage trailer has a duplex cover.
arodriguez60 is offline   Reply With Quote
Old 04-01-2010, 08:40 PM   #16
1969 25' Tradewind
1983 34' Limited
Images: 85
Here is a pic of the 69 you can see the outlet on the left of the pic. It is a single outlet. On my avatar I think you can see the duplex outlet near the battery compartment
Old 04-01-2010, 09:02 PM   #17
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks, Anthony! It's interesting to see the different placements.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 04-05-2010, 04:33 PM   #18
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Completed the installation on Saturday with expert help from friend and fellow Airstreamer Brad Norgaard (FLYFSHR) (see pic below). Even though we both agreed that the location for the new outlet was perfect, I was a bit apprehensive cutting holes by myself but having Brad around calmed my nerves (he did most of the cutting). The hardest part was getting the holes cut just right for the metal outlet box.
This project was made easier by the fact that the storage compartment already had an 120v outlet in it. This oddly placed outlet took up a fair amount of room in an already limited storage area, so this modification was a win-win for me. We simply used the wiring from this old outlet. I'll strip and polish the new outlet when I polish the Airstream later this year.
1958 Overlander
4CU 1st VP
Old 04-05-2010, 05:42 PM   #19
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Looks good Mike, I have the same problem when it comes to making holes in the skin of our trailer too. BUT when a friend needs a hole I run right over and dive right in. (is that strange)
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 04-09-2010, 11:21 AM   #20
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
That is not strange at all. I had no hesitation cutting into Mike's skin. Although we measured about four times before making that first cut. We checked for ribs and electrical behind the skin because once that first cut is made, you're committed.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Adding an outlet Boondocker Electrical - Systems, Generators, Batteries & Solar 45 03-10-2010 08:06 PM
Microwave 110v power outlet location? SnoSheriff Stoves, Ovens & Microwaves 1 07-24-2009 12:46 PM
Exterior outlet RLS Electrical - Systems, Generators, Batteries & Solar 10 06-22-2009 10:37 AM
Adding Exterior Outlet Ganglin Lights - Interior & Exterior 4 09-18-2007 09:27 PM
Adding a 12VDC outlet outside?? myoung Electrical - Systems, Generators, Batteries & Solar 6 08-25-2006 05:42 PM
