Old 03-30-2006, 03:31 PM   #1
DocBear's Avatar
Milwaukee , Wisconsin
Adding a battery (or two)
We're fast approaching ownership, but looking at our available information, I'm a little curious about the electrical system in actual use.
Even if we get a unit with 2 batteries, would it be fairly easy to add another 1 or 2 to the setup to optimize our "off the grid" life?
DocBear is offline   Reply With Quote
Old 03-30-2006, 03:45 PM   #2
Images: 59
I would think so, provided you have a big enough converter/inverter/3-stage charger to keep them adequately charged.
And you don't exceed the load capacity of your axles.
Old 03-30-2006, 08:15 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
A 55 amp converter will keep 2 group 24 batteries charged nicely (standard on the 19CCD0. If you go for ....say 4, I might upgrade to a 75amp model. Also, consider using AGM batteries. They are sealed and can be used in any orientation and are especially suited for indoor use as they do not gas and require less ventilation than liquid filled types.
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 01:03 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
