Old 07-19-2016, 12:03 PM   #1
1976 31' Sovereign
1990 34.5' Airstream 345
Lost somewhere in , Canada
Adding a 120V outlet beside polarity light box
Perhaps you guys can steer me right here with this question.
on my 76 sovereign I have the polarity light box just beside the hot water heater.
There are two wire casings coming into that box. The polarity light is connected to the combined grounds (from each casing) and the neutrals and the hot wires from each casing are just connected together.
I would like to add an electrical outlet on the inside of the trailer in that location.
My question is can I just pull hot and neutral and ground off that box to run an outlet inside the trailer beside the polarity box?
Thanks in advance.
quicker is offline   Reply With Quote
Old 07-19-2016, 01:06 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If that is original wiring, and you can check it black to ground should be hot, then yes you can parallel another receptacle of those connections. Keep in mind that the new receptacle will be on the same circuit breaker as what ever was feed from that box.
2004 Excursion 4x4
Old 07-19-2016, 01:16 PM   #3
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
Yes you can. Airstream did just that in some models.
Al Boondy is offline   Reply With Quote
Old 07-19-2016, 02:07 PM   #4
1976 31' Sovereign
thanks guys
120v AC outlet hums Prairie Sprinter and B-van Forum 15 02-05-2016 09:31 AM
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box 59as Airstream Classifieds 0 09-19-2014 11:01 AM
Install New 120v Circuit and Outlet dbj216 Batteries, Univolts, Converters & Inverters 14 04-09-2014 04:07 AM
WANTED: beside the door handle for 1970 Overlander or close. bookman General Repair Forum 6 07-31-2008 07:58 AM
any other strange hobbies beside airstreams remcolent Off Topic Forum 41 06-15-2008 11:33 PM
