I'd like to add a 12-volt DC outlet on the road side of our trailer. The reason for this is that we have 12-volt air compressor with an 11-foot chord and cannot find a way to reach any of the three 12-volt outlets inside the trailer: under the dinette, on the fridge wall with the TV fixture, and in the bedroom also with the TV fixture.
The 11-foot chord allows us to use the outlet under the dinette to reach the sidewalk side thru the door, but reaching the other side would require passing the chord thru the screen window. That's not easy to do because the 4 wire clip that hold the screen in place are very stiff and require removal from the outside, far to difficult and problematic.
So, it would appear that the best solution would be to put a 12-volt outlet in the space behind the fridge which has a louvered outside door right above the wheels. Now, how to wire this into the circuitry of the Airstream. I'm electrically-challenged but with a little guidance could probably figure out how to do this.
Any ideas, diagrams, alternatives? Thanks in advance.
MIke,
You have the problem 90% solved already by the description in your post. Your refrigerator is fed by a 12 VDC power connection. You can tap into those 2 wires to get the power for your 12VDC outlet.
The benefit is that you don't have to cut the skin of the A/S....just mount it INSIDE the refer door! It will also be out of the way. Be sure to get a weatherproof outlet. www.powerlet.com has lots of those mainly used for motorcycles but will work perfectly for your application. Your local auto parts store might have one also.
At the bottom of the fridge, you will find a white plastic terminal block with 2 wires coming in and 2 going into the refer control board. The 2 input wires should be red and white, with red + and white -. Just loosen the retaining screws and add your new wires for your new outlet and re-tighten.
I would suggest that you pull the fuse for the refer BEFORE doing this to avoid any shorting of the + lead, which would blow the fuse anyway.
I had the same trouble with my compressor, than I got a cordless compressor/jumper/12V power supply, cost $44.00
at Sam's Club.
I have had it for 18 months and use it all the time
I really like Lew's idea, and might just add it because.
Good idea on the fridge 12V. I was wondering where a good place would be to mount and accessory plug on the outside, and you suggestion is nothing short of genius! It made me fell so dumb for not thinking of it first! :
__________________ Chris - Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas! 2008 Dodge Ram 2500 6.7 CTD Mega Cab 1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
or pink and white!
the end result is the same, colored wire is + white wire is -
john
you call them ferrets, i call them weasels.
