Old 07-02-2016, 06:33 PM   #1
2009 20' Flying Cloud
Poway , California
Add second airconditioner
27 foot 2012 flying cloud; I want to add a second air conditioner.
Any advice?
jfarrar is offline   Reply With Quote
Old 07-02-2016, 09:27 PM   #2
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Following.
Mike
Caffeinated is offline   Reply With Quote
Old 07-02-2016, 09:46 PM   #3
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Instead of adding a second AC, I upgraded my older 13,500 to a new Penguin II HD improved version. So glad I did. It has proven to be much quieter, more efficient and keeps our AS cool at over 100 degrees. I'm sure that 2 AC's will definitely cool yours, I wanted my roof for additional mods like satelite dish and solar panels.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 07-02-2016, 11:20 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Any advice?
Hmmmmm.........
Considering that I don't think you are pre-wired for a second unit, it will be a chore to get that additional 20 amp 120VAC circuit up to the fan location that you plan to use for your second A/C unit. You would probably need to remove part of the ceiling to be able to run the cable, and be certain that the location is re-inforced for the weight of the A/C unit.
And after you convert your breaker box, power inlet(s) and transfer switch (if you have one) to 50 amps, if you intend to use your existing zone control thermostat, you will also need to run a phone-type data cable from the first unit to the second, which will be a chore unless you do it when you remove some of your roof panels.
Setting 2 units for single t/stat operation will be the simplest part!!!
Add a second air conditioner to a 27' or 28' AS johnlanglois Furnaces, Heaters, Fireplaces & Air Conditioning 12 12-13-2014 04:39 PM
Can I add second battery from different brand? Eresan 2005 and newer - Bambi all models 8 06-08-2014 06:40 PM
Is it possible to add a second Fantastic Fan? m.hony Roof Vents, Skylights & Fans 6 05-31-2013 02:38 AM
Add a second battery? dmac Electrical - Systems, Generators, Batteries & Solar 23 08-19-2009 11:20 PM
Bay breeze airconditioner yaakman 1965 Safari 2 04-04-2006 09:47 PM
