Old 12-28-2014, 01:02 PM   #1
Yertle01.com
TRizzuti's Avatar
2006 22' International CCD
Estes Park , Colorado
Adapter Confusion
I'm not only a newbie but also completely electricity-illiterate, so I'm not even sure how to ask this question, but here goes. My 2006 22' CCD is 30-amp and I'm going to a private campsite next summer that will only have a 50-amp connection. Do I need an adapter, and if so, which one? I'm confused by the numbers. Is there such a thing as a 50- to 30-amp as well as a 30- to 50-amp adapter? Does it matter which way the adapter is hooked up between the Airstream electrical cord and the campsite plug-in? Thanks in advance for any help.
Terry P. Rizzuti, "Yertle"
TRizzuti.com
Yertle01.com
"My two cents is worth every penny."
TRizzuti is offline   Reply With Quote
Old 12-28-2014, 01:27 PM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
YES. There is a 30a-50a adaptor. Likely there is one for the other direction also. You should have one and also get one for 30a-20a for those times too. You will then be prepared for whatever you should encounter. They are pretty self explanatory when you see them. One side ( for the trailer end 30a) is a female plug and the campground end is a male plug 50a.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 12-28-2014, 01:38 PM   #3
2005 19' Safari
GLENDALE , AZ
This is what you need:
Road Power 09554-90-08 10/3-Gauge 30-50-Amp RV Adapter Power Cord, 18-Inches - Walmart.com
The 4-prong, plug goes into campsite's 50 amp electrical box, and your Airstream's shore power connector plugs into the 30 amp socket.
Old 12-28-2014, 02:06 PM   #4
1974 Argosy 20
Kooskia , Idaho
Very often campsites which have 50 amp service also have a 30 amp outlet in addition, so you would need no adaptor. You might call the campground and ask if they have both at their sites.
The adaptor is nice to have though, just in case.
Old 12-29-2014, 04:02 AM   #5
2005 19' Safari
GLENDALE , AZ
I bought an adapter, to have "just in case". Last spring, it got used for the first time after carrying it around for a couple of years.
One of the Washington State campgrounds on the coast had both 30 and 50 amp receptacles, but the 30 amp socket was worn out and corroded. However, the 50 amp connector was brand new and unused. This adapter saved us from having to move to another campsite.
Old 12-29-2014, 06:48 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I've had the same thing happen at one Louisiana State Park and two Mississippi State Parks. The 50-male to 30-female adapter was a trip-saver— in more ways than one; it saved my camping trip, and prevented circuit breaker trips!
In all three cases, the 30-amp socket was discolored, which was an immediate cue that the socket was bad. If the contacts don't fit tightly for whatever reason, an electrical arc will form across the contacts, causing the socket to get hot and causing the plastic of the socket to discolor due to the heat.
Cats and ultraleather Airstream upholstery don't mix!
Old 01-17-2015, 02:34 PM   #7
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
on a somewhat related note.
i have 2 30 amp power cords each with a twist-lock at one end [ into the the AS ] and the usual plug end for the campground electric box at the other.
i have read that some campgrounds have the boxes somewhat far from where you park your RV.
is there a way [or an adapter] to connect the 2 power cords?
i see that CAMCO sells an adapter used for connecting a 30 amp cord to a genterator.
i know that this would be a rather extreme circumstance where one of my cords wouldn't reach but it might be a good gadget to have.
anyone had the same thoughts?
az-streamer
Jon & Deb
Phoebe & Ellis - Airstreaming Mini-Schauzers
FCU WBCCI #1601
I Don’t Always Pull A Trailer
But When I Do - I Pull An Airstream
Keep Moving My Friends
az-streamer is offline   Reply With Quote
Old 01-17-2015, 04:10 PM   #8
I've never seen a twist-lock adapter. However, you can buy an RV extension cord with 30-amp male on one end and 30-amp female on the other. I have one that I bought at Cabelas. Used it yesterday, in fact, when I was using a friend's courtesy parking, and his 30-amp service was just a bit too far for my cord to reach.
Old 01-18-2015, 01:02 PM   #9
Images: 20
thanks for the reply.
yup - i'll probably just by an ext cord with 30 amp plugs.
an adapter, if one was available, would likely cost almost the same.
even though our AS has an electrical hook-up at each end, i would hate
to get to a campground where the box is on the wrong side and hard to
reach.
same for the water.
az-streamer
Jon & Deb
FCU WBCCI #1601
Old 07-10-2015, 09:58 AM   #10
gaetannicole's Avatar
I read many times these posts about adapter confusion. But I did not find the answer about :
For 30 amperes AS is there more or less secure to use an adapter 50 amperes to 30 amperes because it is not the same voltage and I am afraid to use this kind of adapter?
Envoyé de mon iPhone à l'aide de Airstream Forums
gaetannicole is offline   Reply With Quote
Old 07-10-2015, 10:21 AM   #11
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
You can make one
You should be able to find a 30A female connector, probably at a Camping Supply place, and a twist-lock male connector. Add a couple of feet of 10 ga. SO cord from the same place you bought the twist-lock connector and hook it all up. Hard to go wrong, the connectors usually have the wire colors printed or engraved on them.
I added a twist-lock mating pair in my power cable. On my 2001 Safari the cable was permanently attached in the bumper storage compartment. Every stop I had to fish 25' of power cord through a cover in the bottom of the compartment. I cut the cord and put in the twist-lock connectors and now I pull the whole cable out the top and stuff a couple of feet back in through the cover plate.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-10-2015, 10:26 AM   #12
It is the same voltage, more current on more wires
50 Amp service is like two 30 Amp feeds, that is why there are four wires. The adapter you need has a male plug with four blades. Three of them are wired to a female receptacle with 3 sockets. The fourth wire is not connected. You can use a 50A to 30A adapter to run your 30A trailer on 50A service with no problems.
Al
S/OS #004
Old 07-10-2015, 10:58 AM   #13
In some parks you SHOULD use an adapter, even if 30amp service is available. Especially at State Parks in my experience, the 30-amp outlet is often worn from overuse, and the plug doesn't make good contact, which can lead to arcing across the contacts and therefore increased resistance and increased heat. The 50amp outlet is never as heavily worn as the 30amp outlet, so there's no problem getting good contact.
When you arrive at a campground, look at the 30amp outlet before you plug in. If it's discolored— especially if it looks heated or scorched, don't use it. Use the 50amp outlet with the adapter instead.
12 volt confusion?? COArgosy78 Electrical - Systems, Generators, Batteries & Solar 7 09-21-2004 04:51 PM
Replacing Univolt and 12V confusion sander17 Batteries, Univolts, Converters & Inverters 8 06-29-2004 10:09 AM
Wheel confusion Sneakinup Wheels, Hubs & Bearings 11 02-15-2004 10:22 PM
Confusion-1957 bubble parts smallfry General Interior Topics 5 11-21-2002 06:09 AM
