Old 05-30-2014, 08:33 PM   #1
Mont Vernon , New Hampshire
AC wiring plan
We are rewiring our 63 Overlander and will giving our plan as input to our electrician. Any suggestions on improvements or things to change would be appreciated - thanks.
The AC wiring circuits and parts are as follows:
Circuits:
Main Breaker, 30 AMP
1. AC outlet, 20 AMP
2. Converter outlet, 15 AMP
3. GFCI breaker – 8 outlets, 15 AMP
4. Fridge, Lights - 2 Front LED lights, 2 center LED lights, 2 switches, refrigerator outlet, 15 AMP
5. Microwave outlet, 15 AMP
6.(Spare)
Parts:
Wire – Marine 12/3 – 250 ft (waytekwire.com)
Wire – Marine 10/3 – 6 ft from input to power protection to load center
Connectors – sealed multiple wire butt connectors (waytekwire.com)
Breaker Box - 4 space, 8 Circuit Indoor Load Center
Circuit Breakers - 20 Amp (1), 15 Amp (2), 15 Amp GFCI (1), 30 Amp (1)
Power Protection – Progressive Industries EMS-HW30C
Plugs – Old Fashioned Style (10), 15 Amp
Plug – Old Fashioned Style (1), 20 Amp
Plugs - 1 New style with ½ USB, 15 Amp
Switches – Old Fashioned Style (2), 15 Amp
Plug and switch boxes - Shallow outlet boxes (Vintage Trailer Supply)
NH Hiker is offline   Reply With Quote
Old 05-30-2014, 08:49 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
That #12 wire is a PITA to deal with in shallow boxes, (ask me how I know) you might consider #14 on the 15 amp circuits.
Old 05-30-2014, 09:13 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
12/3 stranded marine cable from Waytek Wire is extremely supple and a joy to work with. I use it on a daily basis. it is NOT ROMEX! Even the 10/3 is very soft and bends with ease. I just finished wiring a 30 Classic with 2 runs of 10/3 marine cable. I would not have dome it with any other type of wire!
Old 05-30-2014, 09:18 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
That is good to know, I wish I had known that a year ago...
Old 05-30-2014, 09:52 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Lewster is correct. Trust his advice and minimize your grief.
Be sure to NOT use solid wire!
If possible I will install wire conduit of high temp plastic in case I need to "rewire". Then again, the original is going strong now so why worry?
Don't forget... Do NOT ground your AC to camper shell!!!! If you do, you may electrify the skin!!! Great for Peeping Toms, lousy for everyone else!
For 12VDC, ground to trailer chassis but run both - and + to each DC device (minimize electrolysis ) and make sure to fuse the circuits with "resettable" breakers... More $ but if you pop a breaker it is easier than looking for the proper replacement glass fuse.
Finally, for your water heater... Will you use AC? If so don't forget to run a circuit!!
Do not "bond" neutral in the breaker box either... GCFI reall hates that.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-30-2014, 09:57 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It is my understanding after lots and lots of research that the trailer skin should be grounded, but the neutral should not be attached to the skin.
The trailer is to be wired as a device.
Water pump wiring and proper wiring Supertwin1 Water Heaters, Filters & Pumps 8 05-23-2014 07:05 AM
Towing Plan - thumbs up or thumbs down? drboyd Towing, Tow Vehicles & Hitches 9 10-25-2005 06:29 PM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
A new kind of "Bounce" plan COArgosy78 Off Topic Forum 47 01-10-2004 01:04 PM
Ideas to change the floor plan / interieur of a 1979 Safari Hans General Interior Topics 0 12-23-2002 10:58 AM
