Old 04-29-2017, 04:05 PM   #1
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
AC Soft Starters
I know everyone on here is familiar with the micro air soft start system for our RV AC's allowing a single AC unit to run off of a 2000 W Honda generator. I know my career has been super gracious and offered a $50 discount with the discount code "AIRSTREAM". And I purchased a micro air system using this discount code BUT.....Has anyone looked at the hyper engineering soft start system. www.hypereng.com available here http://www.gen-pro.biz/shop
The hyper engineering system is about $100 cheaper than the micro air system I would love some input from micro air on what the difference between the two systems is. Just food for thought as I stated I ordered a micro air system yesterday.
Old 04-29-2017, 04:17 PM   #2
Lily&Me's Avatar
Normal , Illinois
As a Commercial Vendor here, Micro-Air is not allowed to post product comparisons.
You might email the company and ask them.
Maggie
Old 04-29-2017, 05:29 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
AC Soft Starters
I could be wrong but my online research seemed to indicate that the hyper engineering product was actually the first generation unit designed by Matteo Giovanetti, also resold by dometic under the smart start brand name. There is at least one video online of Matteo demonstrating the hyper engineering product at a trade show.
I believe that a few years ago Matteo left hyper engineering and started working for micro air and has since designed a newer, improved soft start device.
As an example the micro air easy start has a built in 5 second delay between fan start and compressor start - allowing a generator to first spool up out of eco mode to start the fan before going full throttle to start the compressor. This saves fuel because you can run the generator in eco mode and it won't stall under instant load if compressor and fan try to start at the same time. Also, the easy start has an IP65 enclosure for water resistance and has a 2 year warranty vs one year for the hyper engineering product.
I looked at both devices (actually all 3 if you include the dometic version which is oem hyper engineering)
I decided to by the micro air easy start because it was easier to wire, had better documentation including videos, had an option to buy all the connectors you need for an additional $10 and better overall product support. Matteo will even supply you with a custom wiring diagram for your particular AC unit if needed / desired.
Matteo is very good about supporting micro air customers, and the airstream community. He is extremely knowledgeable and responsive based on my personal experience.
So I think it is safe to say you get what you pay for
wulfraat is offline   Reply With Quote
Old 04-29-2017, 05:35 PM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Thats what i was looking for!!! Thanks wulfraat
Old 04-29-2017, 05:35 PM   #5
2015 30' Classic
Pleasanton , California
Page 2 from Micro Air's datasheet points out some of the differences between their device and the competitor.
It's worth mentioning the following discrepancies:
- Average start surge reduction to 70%: Hyperstart also claims 70%
- Lower Cost: Hyperstart is retailing for $229 with an enclosure
- Fault LEDs on circuit board for easy determination of cause: Hyperstart also includes fault LEDs
- True 6 ton compressor support in largest model (38 FLA): not relevant
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 04-29-2017, 05:40 PM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Well that dosen't sound convincing.
2012 Dodge Durango Hemi/AWD
Old 04-29-2017, 05:43 PM   #7
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
So what I'm getting is the same Guy Design both units similar to Hensley and Pro pride hitches. And in order to avoid Patent infringement made some changes to the system as a second-generation improvement.
Old 04-29-2017, 05:49 PM   #8
2016 16' Sport
Miami , Florida
Also microair offers free tours of their facilities in NJ. Impressive and informative but most of all you get to meet their receptionist.
Shiny16 is offline   Reply With Quote
Old 04-29-2017, 05:51 PM   #9
wulfraat's Avatar
AC Soft Starters
This is my theory but I cannot confirm. You'd have to email Matteo and ask him
Also - the easy start from micro air has led lights as well - you just need to pop off the cover to view the. if you ever need to troubleshoot an error.
Old 04-29-2017, 05:57 PM   #10
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
receptionist? Do Tell
Old 04-29-2017, 06:11 PM   #11
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I just installed my Micro Air. I have not run the compressor on the gen yet. I never heard of the hyper... . But saving $100 is probably not as important to me as the idea that the unit is going to work and that I am going to get help from the company if I need it. Now, how did I miss that $50 discount?
Old 04-29-2017, 06:13 PM   #12
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Micro air offers 50$ off if you use the promo code AIRSTREAM at checkout
Old 06-27-2017, 08:49 AM   #13
Hawthorne , California
Hyper Engineering
Hi,
I installed the Hyper Enginering on my TT with a 13.5k a/c unit. I also work in the HVAC trade. I wanted to see if this unit would be a viable product for homes also. Here is a video I posted of a Yamaha 2000 trying to start the a/c unit. It never started it, at sea level, outdoor amb around 75.The Honda eu2000 had no problem starting the a/c. i tried at 6500ft elevation and the Honda failed to start the a/c without the converter turned off. I am trying to purchase the Micro Air 366 board for an install and test as I type this.
https://youtu.be/E99K9TpW81g
acemech is offline   Reply With Quote
What to use to keep window seals/rubber soft. Safari-Rick Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 03-27-2006 06:24 AM
How do I diagnose the soft spot, and what are the repair options? Narnian Repairing/Replacing Floor &/or Frame 12 09-01-2003 02:41 PM
soft spot repair stellablu Repairing/Replacing Floor &/or Frame 2 08-08-2003 03:18 PM
Soft floor kenny2 Repairing/Replacing Floor &/or Frame 2 01-19-2003 06:21 AM
Starters and more ALANSD Mechanics Corner - Engines, Transmission & More... 12 05-10-2002 06:26 AM
