Old 08-14-2014, 08:04 PM   #1
2008 22' Sport
Newville , Alabama
AC recommendation for 2008 22SS
Looks like I need to replace the AC unit for my 2008 22 Safari Sport. Any one know what unit would be best. I live in the South so unit will get much use. Also any idea if there is anything that would be comparable with the current AirV ceiling unit I have. Much thanks for any help you can give
Bright Spot is offline   Reply With Quote
Old 08-14-2014, 08:43 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Nothing will be compatible with the Air V ceiling assembly. The current model uses a Penguin air conditioner, I think 13,500btu. If you dare to be different, Atwood now makes a roof air that supposedly you can run on a single 2000 watt generator, and is supposed to be low profile. I haven't seen one yet, if you get one, please let us know how it works.
Old 08-15-2014, 10:40 AM   #3
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Wow! What happened? Mine is running fine but now you got me worried.
Ahab is offline   Reply With Quote
Old 08-15-2014, 11:00 AM   #4
2008 22' Sport
Newville , Alabama
Well Ahab, I almost hate to answer that question, but the sad truth is that "I really messed up " I plugged my AS into 220v service and knocked out several parts/services - 12v inverter, TV, micro wave, and AC. All fixed now except AC. Let this be a good warning to other AS owners, Check before you plug.
Old 08-15-2014, 11:39 AM   #5
2008 22' Sport
Newville , Alabama
Talked with the Atwood folks. They do not presently make a low profile unit nor have plans to make one at this tims
Old 08-15-2014, 11:58 AM   #6
2008 22' Sport
Newville , Alabama
Right now it looks like I'm going with the Domestic Penquin Ii. Anyone have a better idea?
Old 08-15-2014, 05:05 PM   #7
Well Preserved
1993 21' Sovereign
Your only other low profile alternative would be the Coleman Mach 8. They are low profile, seem to work well, but be prepared for a lynch mob formed by your fellow campers over the noise it makes. Inside, it's just noisy, outside, I have heard quieter jet engines. While I wouldn't recommend it, it is an alternative.
Old 08-15-2014, 06:01 PM   #8
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
There is now a new fan blade to fix the outside noise problem. New units may already be equipped with the revised fan blade. It not you can order one from the manufacturer.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 08-16-2014, 06:48 AM   #9
adonh's Avatar
1976 31' Sovereign
Here is a link to the iRV2 forum that has a thread covering the new fan blade for the Coleman Mach 8.
RVP/Airxcel/Coleman MACH 8 A/C Quiet Outside Fan Kit - Page 5 - iRV2 Forums
Don Hardman
1976 31' Sovereign
Old 08-16-2014, 08:06 AM   #10
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . WOW, Bright Spot, at least you're honest, some folk wouldn't have admitted that ! I feel your pain, good luck, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 08-16-2014, 08:31 AM   #11
adonh's Avatar
1976 31' Sovereign
How were you bale to plug in to 220V. You would need to use some type of adapter I would assume.
Don Hardman
1976 31' Sovereign
Old 08-21-2014, 08:52 PM   #12
CA_Tallguy's Avatar
1977 31' Excella 500
Zavalla , Texas
Amazing news adonh -- thanks for posting that about the Mach 8. I was an early buyer and it is indeed loud.
WBCCI #1711
Texas Gulf Coast Unit, Texas Airstream Harbor
Angelina National Forest, Zavalla, TX
CA_Tallguy is offline   Reply With Quote
Old 08-21-2014, 09:09 PM   #13
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
The Dometic unit is not a bad unit; however, for your AS, I would suggest an 11K unit which would take less power and is quite capable of cooling the interior as it does my 25'. They have some kind of new grommet to deal with noise to make it quieter, matching the older model noise levels with the different compressor and coolant. The 5 direction air distribution box is nice too. It is hard to say though. The Mach 8 is supposed to be a good unit too.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 12-05-2014, 01:34 PM   #14
CA_Tallguy's Avatar
Zavalla , Texas
FYI - the replacement fan blade I ordered to quiet down the unit lasted no more than 3 or 4 months of heavy usage. The center disk of the fan started to crack near 2 of the blades and it DID crack big time on one of the blades, throwing the fan off balance and causing all kinds of noise. Thankfully I didn't throw away the original blade so that is back in while I check back with RVP. Maybe they have improved the design AGAIN (hopefully) and/or I just got a bad blade or something. I do think it is more of a design issue as the whole center of the blade is deformed and the cracking is on all three blades.
I'm off to the thread ADONH posted to see if anyone else is reporting the problem there.
WBCCI #1711
Moab-recommendation! WolfSong Our Community 33 03-05-2004 09:34 AM
Coupler lock recommendation davidlaxson Hitches, Couplers & Balls 19 02-21-2004 10:11 PM
Colorado Destination Recommendation? Bob Boucneau On The Road... 13 10-01-2003 03:48 PM
Recommendation on weight distribution hitch davidlaxson Hitches, Couplers & Balls 30 08-31-2003 09:38 PM
Recommendation for skin repair in Northeast? rluhr Commercial Listings 5 08-28-2003 09:14 AM
