Old 09-25-2012, 08:36 AM   #1
2009 22' Interstate
Chetek , Wisconsin
AC Outlets 2 Only
Hi Denny here, question on power outlets. The TV outlets do not have power coming to them, they work fine when pluged in to shore power. Previously worked fine. Other outlets work fine. New Inverter was installed and as far as I know two outlets do not have DC power. Work with generator or shore power only.
Thanks WisDenny
Wisconsinden is offline   Reply With Quote
Old 09-25-2012, 07:32 PM   #2
2009 22' Interstate
Chetek , Wisconsin
110 outlet breakers ?
Are there any GFI type breakers to reset power to any outlets. When Inverter is on there is no power getting to two seperate 110 outlets.Other outlets are working fine. WisDenny
Old 09-25-2012, 08:00 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
On trailer factory inverter systems, there are two outlets at each TV. One is for inverter power only and the other is for shore/generator power only. You have to plug the TV into the one you are powering at the time.
doug k
Old 09-25-2012, 08:23 PM   #4
2009 22' Interstate
Chetek , Wisconsin
TV only works on shore power in either side of 110 by TV's. Will continue my search. Inverter is wired corect as other outlets work properly. I can run extension cord to other outlets and they work properly.
Old 09-25-2012, 08:28 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Since they worked before you changed the inverter and they don't after you changed the inverter, my guess is that the inverter was not connected correctly.
Bill
Thanks WisDenny
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 09-25-2012, 08:31 PM   #6
dkottum's Avatar
Yes, but on the trailer there are two completely separate duplex 110 outlets, one for shore/generator power only and one for inverter power only. Maybe the Interstate is different.
doug k
Old 09-26-2012, 07:55 PM   #7
2009 22' Interstate
Chetek , Wisconsin
Correct answer
Bill
Side input 110 wires need reversing according to Airstream expert.
Old 10-02-2012, 03:35 PM   #8
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
Suggest checking both sides with a meter before concluding that the inverter was wired inproperly ...
2015 25' Eddie Bauer Int Sp Ed
2015 Chev Duramax 2500; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 10-03-2012, 04:31 AM   #9
2009 22' Interstate
Chetek , Wisconsin
Thumbs up Inverter was the problem
Two sets of 14 gage on side of inverter. After consulting with Airstream, they determined the previous owner had installed the inverter and reversed the 6 in/out wires. When I reversed the wires, problem was fixed. No damage done. Inverters run the intertainment group while inverting. The other outlets are meant to operate with the A/C power or the generator.
